Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
Thread: Memories
    Super Member steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the drawing office of a joinery shop, part of a building company, most of the work is interior doors and kitchen cabinets.
    AutoCAD LT 2013
    May 2013
    An Englishman in Belgium
    1,951
    Default Memories
    I know this isn't the usual forum to be associated with Autocad LT, I'm just hoping someone here may know how to solve this issue. I have a macro that eventually will repeat several thousand times, to optimise polylines (remove zero lengths, join segments etc. overkill alone doesn't cut it), but that's beside the point. The macro works exactly as I want it too, for 43 cycles, and then it breaks Autocad.
    It took me a couple of days to pin down what was going on, as to why the macro was faulty, but it isn't. After 43 (on my desktop - 33 on a laptop) then Autocad starts acting weird, selections are not recognised but remain highlighted. If I close LT saving the drawing. I then reopen and can run the macro again for the next 43 items. So I have a Windows shell file that runs and repeats Autocad to get through the whole load of polylines, this works but is not ideal.
    From what I have found Autocad can run out of memory resources, and I'm just hoping someone will recognise one of the commands that is causing this so that I can maybe approach this in a different way, or know of a command to free up the memory again, rather than closing and reopening. Regen or saving don't work.
    Here's the macro, and if anyone can help there is also a drawing file with a couple of hundred polylines that I have been using to test it on. Basically, the macro selects the polylines one at a time doe's its thing and then moves them to a frozen layer, so it can get at the next one (I know it's a bit Flintstones but this is LT ). It would be nice if someone can run this and check system resources to see what is going on, which isn't an option in LT.
    Code:
    *^C^C^Cmove;0,0;;0,0;0,0;change;p;;p;la;1;;explode;0,0;ss;l;;m;0,0;0,0;-overkill;p;;;region;p;;l;0,0;10,0;;ss;l;;m;0,0;0,0;erase;p;;explode;l;ss;l;;m;0,0;0,0;pe;m;p;;j;;;change;l;;p;la;2;;
    PS peditaccept has to be set=1
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,038
    What are your system specs?
    What's running in the background?
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2012
    Nov 2014
    Bergen op Zoom , Netherlands
    515
    I have almost zero experience with LT , mainly because you (normally) can't use lisp so I guess command (gc) is out of the question? Would put a couple of qsave's in your macro free up resources? But autocad is known for memory issues. Else find a bigger system to do your work on if the number of drawings is limited... At my work I typically restart autocad a couple of times per day to avoid memory issues and I only work in mdi if needed.
    gr. R.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,038
    Restart AutoCAD a couple of times a day to avoid memory issues? That's absurd. How much RAM do you have? What is your swap file size? Have you tried deleting your graphics cache files (probably only necessary if you routinely work with 3D solids, non-mesh surfaces or regions).
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD LT 2013
    May 2013
    1,951
    @ReMark
    the laptop is a Lenovo Yoga 700
    intel i7-6500 2.50GHz
    with 8GB RAM
    running Windows 10 and Autocad LT 2017LT
    at work, I'm not sure but just found out today that after months of nagging I will be getting a new model in the next week or so.
    Normally I would have Autocad, Revit, Excel plus any number of other programs running, but this problem persists even with a fresh start up and only LT running.
    @rlx (hi neighbour - I'm in Hoogerheide every weekend), Autocads memory hogging is what I'd read, I have tried qsave on every line as well as regen to no avail, I will try saveas see if swapping drawing files works but with thousands of polylines that could end up being an enourmous folder. Purge doesn't help and indeed garbage collection is out of the question in LT. Closing and opening Autocad with the batch file works fine, just a little slower than I'd like and not neat and tidy.
  6. #6
    W10
    Electrical
    Electrical
    AutoCAD 2012
    Nov 2014
    515
    absurd? maybe... but it works for me. Don't know the size of the swapfile but mem is only 4 Gb , now that's absurd. Normaly drawings I use are below 1 mb , a few are bigger. But if I have a really big one I restart my pc , make sure autocad is the only program I start (can't disable company background apps). And to see autocad is really in SDI mode I have a button on my toolbars which changes color to show wheter autocad is in sdi or mdi mode. Autocad isn't great with memory management. Also I hit the qsave button many times during my drawings sessions because I hate work , I hate overwork more , but what I really hate is to have to do the same work again.. so to avoid the message nobody wants (an error has occurd , autocad cannot continue etc etc bladibla...) I frequently save my work.
    gr.Rlx
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,038
    Did you shut down your anti-virus program? Did you shut down your browser? Did you disable all of Win10's bells and whistles?
    Don't tell me we have to go back to the good old days of memory management programs like QEMM.
    Have you tried using ReadyBoost (a feature of Win10). You'll need a USB flash drive.
    Have you used Windows Task Manager to identify resource hogs?
    Have you tried using a RAM cleaner?
    Finally, have you considered adding more physical RAM?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,038
    rlx: Living with a problem is not the same as fixing one. Wouldn't you prefer a long term solution rather than a workaround?
  9. #9
    W10
    Electrical
    Electrical
    AutoCAD 2012
    Nov 2014
    515
    Quote Originally Posted by steven-g View Post
    @ReMark
    with 8GB RAM
    Hallo 'buurman' :-)
    Guess you have read all (vl-every / vl-some) of the autocad links which say , well , nothing usefull but to get more Ram...
    If time is not an issue you can cut up your drawing or the process it self but I agree it's not elegant. I did once have a drawing , something like 40 mb , tiff converted with winTopo , so even every letter is a bunch of lines. In the end I just redrawed the d*mn drawing myself because connecting al the dots , changing layers / styles etc just wasn't worth it.
    gr. Rlx
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2012
    Nov 2014
    515
    Nice one , maybe something to put on a tile for on the wall :-) But I have to work with the tools given to me so sometimes I have no choise but to work arround the problem...
  1. 35 Years of Autodesk and AutoCAD Memories
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 13th Jan 2017, 02:54 pm
  2. Can AutoLISP saving more memories
    By Pither Rukka in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Nov 2010, 01:45 pm
