Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2017
    Jun 2017
    4
    Default AutoCAD VBA - count hatch areas
    Hello,
    I would like to write a procedure (function) which will show how many hatch areas are on the drawing. For example:
    I have drawing which has 3 objects (2 rectangulars and 1 circle - all in layer 0.
    1 rectangular and 1 circle is hatch. So when I will start the function it will show message about 2 hatch objects.
    Senior Member
    AutoCAD 2009
    Oct 2012
    342
    Try it
    Code:
    Public Sub HatchCount()
    'On Error Resume Next
    Dim ObjSS
    Dim SSitems
    Dim FilterType(0) As Integer
    Dim FilterData(0) As Variant
    Set ObjSS = ThisDrawing.SelectionSets
    For Each SSitems In ObjSS
    If SSitems.Name = "Nabor" Then
    ThisDrawing.SelectionSets.Item("Nabor").Delete
    Exit For
    End If
    Next
    Set SSitems = ThisDrawing.SelectionSets.Add("Nabor")
    FilterType(0) = 0
    FilterData(0) = "HATCH"
    SSitems.Select acSelectionSetAll, , , FilterType, FilterData
    'or
    'SSitems.SelectOnScreen FilterType, FilterData
    If Err Then Err.Clear:  Exit Sub
    If SSitems.Count - 1 = -1 Then
    MsgBox "Selection empty !", vbExclamation
    Exit Sub
    End If
    MsgBox "HATCH - " & SSitems.Count, vbSystemModal + vbInformation
    End Sub
    Forum Newbie
    AutoCAD 2017
    Jun 2017
    4
    Thank you. It works but I see some issues. For example:
    1. I drew 3 circles
    2. Next I went to Hatch Creation and made hatch in 2 circles
    3. Finally I closed Hatch Creation
    Then the function will say about 1 hatch object.
    But if I change actions:
    1. I drew 3 circles
    2. Next I went to Hatch Creation and made hatch in first circle
    3. I closed Hatch Creation
    4. I went to Hatch Creation again and made hatch in second circle
    5. I closed Hatch Creation
    Then the function will say about 2 hatch objects and this is correct result.
    Do you have any ideas how to improve this function?
    Also if it is not a problem I would like to ask about help in:
    - make this function also let the user to change hatch pattern to solid with possibility to choose color.
    Senior Member
    AutoCAD 2009
    Oct 2012
    342
    Quote Originally Posted by avagorn View Post
    No. Only individual hatching. Otherwise it does not work.
    It is necessary
    - or know exactly what type of fill and color
    - or make a form that will select the color you want.
  5. #5
    Forum Newbie
    AutoCAD 2017
    Jun 2017
    4
    Quote Originally Posted by maratovich View Post
    It is necessary
    - pattern type: ANSI31, Hatch Pattern Scale 10
    - form with colors will be great
  6. #6
    Senior Member
    AutoCAD 2009
    Oct 2012
    342
    Code:
    Dim ObjSS
    Dim SSitems
    Dim HatchItem As AcadHatch
    Dim color As AcadAcCmColor
    Dim Version As String
    Exit For
    End If
    Next
    FilterType(0) = 0
    'or
    Exit Sub
    End If
    Version = Left(ThisDrawing.GetVariable("ACADVER"), 2)
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Version)
    color.SetRGB 80, 100, 244
    For Each HatchItem In SSitems
        HatchItem.SetPattern acHatchPatternTypePreDefined, "ANSI31"
        HatchItem.PatternScale = 10
        HatchItem.TrueColor = color
        HatchItem.Evaluate
    Next
    MsgBox "Ok!", vbSystemModal + vbInformation
    End Sub
  7. #7
    Forum Newbie
    AutoCAD 2017
    Jun 2017
    4
    Sorry for late reply. The procedure works good. Thank you very much for help.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    You can get at the number of individual hatches that make 1 bigger hatch pattern if you dump a hatch you will see the variable "numerof loops"
    Code:
    (vl-load-com)
    (defun hatchnum ( / x num ss tot)
    (setq ss (ssget (list (cons 0 "hatch"))))
    (setq num (sslength ss))
    (setq tot 0)
    (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
    (setq tot (+ (vla-get-numberofloops obj) tot ))
    (alert (strcat "There is " (rtos num 2 0) "hatches\n\nMade up of " (rtos tot 2 ) " sections"))
    (hatchnum)
  1. solid hatch closed areas of drawing
    By Barry_47 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2014, 05:48 am
  2. Strange! about hatch areas weight calculation.
    By elfert in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Apr 2012, 10:35 pm
  3. Problems with calculating areas of hatch
    By BenGoble in forum AutoCAD General
    Last Post: 27th Jul 2009, 05:16 am
  4. total hatch areas
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 5th Oct 2007, 04:41 pm
  5. Hatch areas
    Last Post: 13th Sep 2007, 07:17 pm
