Results 1 to 5 of 5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Default Show calculation in MText
    hi
    in MText i can use formula to calculate,
    but the field show the result, what is i want to show all the calculation way and the result, all simply in a field?
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    826
    Not sure what you're trying to do, but I've used tables to do that before. Each value would have to be in a separate text object for a formula to reference.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    I just want to type in the mtext a + b = c.
    Sent from my MOBIX M6 using Tapatalk
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    321
    So you want to get a bit of mtext showing 3 + 4 = 7?
    I'd do it as a field to read a value to say "3," another to say "4," then your third and final field would be the formula one (which it sounds like you've already created), which calculates the result as "7."
    dJE
  5. #5
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    826
    Quote Originally Posted by samifox View Post
    I wish I could fly!
  1. Mtext field within dynamic block wont show attribute vaule
    By JADT in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2014, 01:19 pm
  2. Trying to use IF statement with calculation?
    By tzframpton in forum Revit MEP
    Last Post: 10th Apr 2013, 03:37 pm
  3. Distance Calculation
    By jose_john in forum AutoCAD Beginners' Area
    Last Post: 21st Aug 2008, 12:54 pm
  4. MTEXT SHOW LINES INSTEAD OF TEXT
    By Scale in forum AutoCAD Drawing Management & Output
    Last Post: 29th Aug 2006, 01:30 pm
  5. calculation
    By cadmuska in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jul 2006, 02:07 pm
