Results 1 to 3 of 3
    Senior Member kippax's Avatar
    AutoCAD LT 2015
    Jul 2007
    Manchester, UK
    182
    Default Editing a Block in Place
    Have to do this quite often, but unlike when editing a block, I can't find a "save as" option.
    Using ACAD LT 2015.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,593
    By edit in place, do you mean you are using the REFEDIT command?
    R.K. McSwain
    CAD Panacea | twitter
    Senior Member tmelancon's Avatar
    tmelancon's Computer Details
    Windows 7 Professional
    Dell Optiplex 7010
    i3-3220 Processor (Quad Core, 3.30GHz)
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Dual Dell 27" Monitors!!
    Multi-disciplinary
    tmelancon's Discipline Details
    CAD Operations/Design
    Multi-disciplinary
    CAD Design, CAD Management, Project Management, ISO Drawings, Pressure Vessels, Inspection Reports, Data Analysis, Work Scope Recommendations, Troubleshooting, and anything else the boss needs to maximize efficiency. Also proficient in Electrical Engineering/Lighting Design and LEED Green Energy
    AutoCAD 2015
    Jun 2013
    327
    If you are talking about REFEDIT then you should see REFCLOSE. See attached image.
    If you mean that you accidentally x'ed out of that little toolbar while REFEDITING, then type REFCLOSE <enter> <enter>. This should save and get out of REFEDIT. You can then proceed to run REFEDIT again to step back in and your toolbar should know be visible. Hope this helps.
    It is better to remain silent and be thought a fool, than to open your mouth and remove all doubt. -Abraham Lincoln
  1. Top Secret In-Place Attribute Editing in AutoCAD!
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 9th Sep 2015, 12:40 am
  2. Replies: 6
    Last Post: 25th Jul 2012, 06:53 pm
  3. Can't select block for in-place editing
    By fostertom in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th May 2010, 11:42 pm
  4. In place refernce editing
    By Mr D in forum AutoCAD Beginners' Area
    Last Post: 5th Jan 2008, 03:08 pm
  5. SIZE OF IN PLACE EDITOR WHEN EDITING MTEXT
    By graham in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2006, 04:33 pm
