Results 1 to 3 of 3
    Forum Newbie
    Civil
    AutoCAD 2017
    Jun 2017
    2
    Default Need lisp to arrange raw ts survey data..
    Hello everyone i need a lisp to arrange raw data taken from total station during land survey and arrange it regularly....find the attachment below
    Thanks and have a good day.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    A method not code pick top bottom points, pick control pt, then use a perp routine to do what you want. Version 1 may be pick pts and draw, version 2 would be some form of window pick. You could do it now maybe using the method I suggested manually doing dims and perp to a line.
    Set ucs to the line then dim Hor and ver will work.
    Forum Newbie
    Civil
    AutoCAD 2017
    Jun 2017
    2
    Thanks for your consideration but sir i don't know much codeing if you could something then it would be great help.
    thanks
  1. Need a lisp to re-arrange the polyline by giving start and end point
    By rk25134 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2015, 07:53 pm
  2. Attribute Export via Express Tools - How to arrange exported data in inumerical ord
    By SimonC in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jun 2015, 01:27 pm
  3. Points from survey data
    By NEWMAN1006 in forum Civil 3D & LDD
    Last Post: 20th Aug 2014, 02:14 pm
  4. Downloading Survey Data
    By Vikes_Fl in forum AutoCAD Drawing Management & Output
    Last Post: 16th Dec 2007, 11:22 pm
  5. Importing survey data
    By pendoggett in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Feb 2006, 11:34 am
