+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default 2018 CAD Linetype Will Not Change
    I am using 2018 AutoCad and can not get the linetype to change. I have never had this problem before and have tried everything I know how to do. I have tried changing the scale, changing it using layers, changing by single line, PSLTSCALE, everything I can think of. It is not change in model or paper space. I am trying to change continuous line to dotted. Thanks the help.
    -David
  2. #2
    Super Member
    Computer Details
    tombu's Computer Details
    Operating System:
    Windows 7 64-bit
    Computer:
    Dell
    Discipline
    Civil
    tombu's Discipline Details
    Occupation
    Design Analyst
    Discipline
    Civil
    Details
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Using
    Civil 3D 2018
    Join Date
    Dec 2010
    Location
    Tallahassee, FL USA
    Posts
    744
    Default
    It could be lots of things like extrusion direction, visual style set to something other than 2D Wireframe, or an intelligent object. Is it all lines in a viewport or model space or just one line?
    A line with a big difference in elevation could be a problem as well.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  3. #3
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    Thank you for getting back, it is any line, i just drew one line to see if it was something like that and it would not change either. Doesn't work in model of paper space. the only thing I am doing different than usual is using decimal units instead of architectural units.
  4. #4
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    also just a straight horizontal line
  5. #5
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    how do I make sure it is in 2D Wireframe
  6. #6
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,017
    Default
    Set linetype to dashed and ltscale 0.25 and have a look. How long is the line if you draw 10 it should appear. Using 2018 no probs.
  7. #7
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    That did work thank you very much. Any idea on how to get dimension text on the left right side of the arrow instead of the left.
  8. #8
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    Also how do you make the linetype the same in model and paper space?
  9. #9
    Forum Newbie
    Discipline
    Architectural
    Using
    AutoCAD 2018
    Join Date
    Jun 2017
    Posts
    7
    Default
    Figured out that PSLTSCALE but still can not get dimension text to the right of the arrow.
Similar Threads
  1. How to change text in a linetype
    By bumblebbabe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 31st Jul 2014, 12:56 pm
  2. Change Linetype
    By jmerch in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2012, 09:29 am
  3. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  4. cannot change linetype
    By shooter1 in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 09:32 pm
  5. How do I change linetype alignment?
    By gbuckley in forum AutoCAD Beginners' Area
    Last Post: 24th Jun 2010, 02:38 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
