Results 1 to 10 of 10
Thread: autoscript
    Full Member
    SRN's Computer Details
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    Default autoscript
    Does autoscript work with 2015LT?
    I followed the other thread about using it with 2012 nad used the menuload command. but appload is an unrecognised command in 2015LT. Autoscrpit now appears as a ribbon panel but if you try to use it it also is an unrecognized command.
    Does anyone know how to enable it?
    thanks
    SRN
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    What are you trying to load using the APPLOAD command?
    Full Member
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    a previous thread asked how to get autoscript working after an upgrade to Autocad 2012.
    The solution that worked was to use the menuload command and then an appload command.
    Menuload worked for me to get it to showup on the ribbon but the application still tells me that autoscript is an unknown command.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    To my knowledge AutoSCRIPT is not compatible with AutoCAD LT.
    APPLOAD command description: Loads LSP, VLX or ARX applications. I don't believe this command is available in LT as well.
  5. #5
    Full Member
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    "they call me john" was the poster and solver or the previous thread i referenced.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Quote Originally Posted by SRN View Post
    That's nice to know but it doesn't change anything. What works in full AutoCAD may not work in LT.
  7. #7
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,146
    Appload isn't available in LT as that is used to load Lisp and VBA
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Quote Originally Posted by steven-g View Post
    Just as I figured.
    Note that the CADig website clearly states the following disclaimer re: AutoSCRIPT...
    System Requirements
    Full AutoCAD 2007 or higher (Excluding AutoCAD LT)
    or full AutoCAD 2007 or higher based products, such as Architectural Desktop, Map, Building System and Mechanical
  9. #9
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,146
    Yeah menuload will get you all setup with things in the menu bar, in LT we can create and use custom menus, ribbons etc. but from there it probably relies on some higher level language so LT will fail at that point.
  10. #10
    Full Member
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    thanks for the expert info guys
  1. Script Not working with autoscript, but works when I paste direct into command line
    By callvey in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 8th Aug 2013, 05:55 pm
  2. ScriptPro/ Autoscript not supporting LISP use?!
    By DWG Destroyer in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Feb 2013, 04:48 pm
  3. AutoScript 2012
    By TheyCallMeJohn in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 12th Apr 2011, 09:12 pm
  4. Hollow Text and Autoscript HELP
    By GTUnit in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Apr 2008, 03:21 am
