Results 1 to 4 of 4
    Full Member
    SRN's Computer Details
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    Default moving between layers
    is there any way to more an item from one layer to another without having to recreate it on the destination layer.
    This is in Autocad 2015LT
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    The quickest way is select the item(s), and open the properties palette, and select the new layer from the layer names drop down list (if you have the layer list on the QAT you can do the same there or again with the layer list in the ribbon), or from the command line with the command "change", there's probably a couple more ways as well
    Full Member
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    thanks that works
    AutoCAD 2013
    Nov 2011
    6,056
    I would probably do it like steven suggested, it could also be done with the Offset command.
  1. Replies: 6
    Last Post: 13th Jan 2017, 03:02 am
  2. A button macro to Thaw frozen layers and Freeze thawed layers
    By YZ in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 31st Jul 2012, 07:23 am
  3. Why are my blocks not moving layers?
    By zantaff in forum AutoCAD Beginners' Area
    Last Post: 12th Nov 2011, 05:57 pm
  4. Moving objects to new layers
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jan 2010, 04:43 pm
  5. moving objects to different layers
    By gib65 in forum AutoCAD Beginners' Area
    Last Post: 17th May 2006, 10:20 pm
