Results 1 to 8 of 8
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    Default Why would my triple dash line appear as a double dash line?
    Hello, I am using some filters in Revit 2018 to make my piping show up as certain lines, and I have my hot water return line set up to be orange and triple dash. I have my regular hot water line set to show up as red and with a double dash line. However, when I started to draw my pipes in, they are both showing up as a double dash. Has anyone noticed any issues with line types in Revit 2018 or would anyone know any reason why it is not showing up correctly? Thanks in advance for any help!
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Have you double checked the Filter? Also, don't forget about Graphic Overrides, which is something other than Filters which can conflict depending on how they're set up.
    Can you post more screenshots of your Filters and your Graphic Overrides?
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    Here is how my filter is set up, I am pretty sure it's not something that is happening from a graphic override. Ive used the same filter in earlier versions of Revit with this same template and it never had any issues before.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    What about your System Graphic Override? Screenshot attached shows where to check this:
  5. #5
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    I did not think to check that, but it doesn't seem to be the issue either. It is set to make domestic hot water always red, and I have the filter set to change pipes with system names set to have 'HWR' in it. What confuses me is the filter is working as far as changing the color, and it does change the line type to be double dash, but it is set to change it to triple dash instead. I don't know where the double dash is coming in.
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    The only other thing I can think of is this: Filters are hierarchical, meaning the order from Top to Bottom matters. Filters at the top retain priority. Select the HWR1 Filter and use the "Up" button so that it's at a higher level than the Domestic Hot Water Filter.
    See if this does the trick.
  7. #7
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    That did it! I was not aware of the filters being hierarchical, thank you very much for the help!
  8. #8
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Glad it worked.
    -TZ
  1. Create 3 dash line
    By Blam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Jul 2012, 09:27 pm
  2. dot-and-dash line
    By demeon in forum AutoCAD Beginners' Area
    Last Post: 13th Dec 2009, 04:40 pm
  3. dash line
    By Yonatan Tamir in forum AutoCAD General
    Last Post: 6th Nov 2008, 02:16 am
  4. Dash line, lights
    By ChloeG in forum AutoCAD Beginners' Area
    Last Post: 25th Oct 2008, 07:39 pm
  5. Hidden Line dash sizes...
    By brasi333 in forum AutoCAD Beginners' Area
    Last Post: 3rd May 2008, 05:56 pm
Tags for this Thread
