Results 1 to 3 of 3
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,609
    Default OK, I am going to design a garage in Revit. Need assistance and guidence.
    I am doing a side project for someone in CAD but I also want to do it side by side in Revit. Not going to charge the client for the time to learn it in Revit but I want to learn how to do it.
    It's a simple design 24'x24' garage with an upstairs area. 9' lower ceiling height with 2x4 wall construction, 8" CMU foundation with poured footings.
    OK, 1st off I do not see a 2x4 exterior wall style in my list. Do I have to create one or start off with a generic wall style and then edit it?
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Correct! You will be creating a Wall Type.
    What I would do first is make sure you have your levels set. You have to do this in a section or elevation view. You'll want the following Levels created:
    • Foundation (Height is bottom of footing, will be a negative elevation)
    • Level 1 (0'-0")
    • Level 2 (Whatever height this will be)
    • Roof (Optional)
    Then, the easiest way to get moving is to create a temporary wall off to the side. Select it, click "Edit Type" in Properties then Duplicate the Wall Type and rename it accordingly. While still in Type Properties, click the Edit button associated with the Wall Structure parameter and set the values as needed. You now have your Wall Type created. I'm sure Youtube has tons of this stuff online to show you.
    Hope this helps!
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,609
    Ah, good tips, thanks bro! I'll do these and report back to the "class"
    Sean
  1. Should I Use Revit for Conceptual Design? Maybe. Maybe Not!
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 17th May 2017, 03:10 pm
  2. Revit for interior design?
    By drfabinex in forum Revit General
    Last Post: 23rd Sep 2009, 02:12 pm
  3. New To Rhino....Need your guidence
    By santosh.jamble in forum Rhino
    Last Post: 27th Mar 2009, 12:23 pm
  4. mechanical design assistance required
    By bolton78 in forum Catch All
    Last Post: 21st Feb 2009, 08:59 am
  5. Revit and sustainable design (big in the UK)
    By James in forum Revit General
    Last Post: 19th May 2008, 11:34 am
