Results 1 to 9 of 9
    Forum Newbie
    Architectural
    AutoCAD 2018
    Jun 2017
    4
    Default My GA plan doesn't fit onto page
    Hello, I have 6 storey buiding, each storey has a GA plan scaled 1:50@A1, but one of them doesnt fit on the page as it has Mews at the back, can I separate it or how would I go on about it? If I would change the scale the others would look lost on the page, could I have a different scale on this plan to others? Thank you
    Forum Newbie
    Architectural
    AutoCAD 2018
    Jun 2017
    4
    Default Can I split the drawing if too big?
    Hello, I have project where all GAs are 1:50@A1, but one has Mews at the back so its too big for the page, can I split it? If I change the scale on all of them the others would look too small on the page, or can I have one GA on different scale? Thank you
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Keep the scales the same on each page. Show the Mews (whatever that is) on another sheet, use matchlines on each page so it is obvious how they go together.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Mews = a row of stables with carriage houses below and living quarters above.
  5. #5
    Forum Newbie
    Architectural
    AutoCAD 2018
    Jun 2017
    4
    Thank you how do I insert those? What is the shortcut for match line?
  6. #6
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Everywhere I have worked we used a wide phantom line type with MATCHLINE A11, and on the other sheet MATCHLINE A10. The matchline should be the full width of the view. Don't show parts of the other sheet in the views, should be as if you cut through the building and moved them apart. Others here may do things differently as there isn't an industry standard written down and agreed to anywhere.
  7. #7
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    321
    Are the mews physically attached to your bigger block or detached?
    If they're detached, then I'd do a separate set of drawings for them, with a site/block plan @ 1:200 or 1:500 showing how they relate to each other.
    If they're attached, either use a break line as described above, or jump up a sheet size to A0.
    dJE
  8. #8
    Forum Newbie
    Architectural
    AutoCAD 2018
    Jun 2017
    4
    Default thank you can you just explain what MATCH LINE 11means?
    Do I just write Match line 11 to one and Match line 10 to the other plan? Sorry this might be quite obvious
  9. #9
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,211
    Quote Originally Posted by maxi2014 View Post
    I believe rkent is giving you an example. A match line (or break line, they're synonymous) shows where one sheet ends and another begins. For instance, if an architectural plan is named A10 and shows the house, and A11 shows the mews, the match line on A10 would be labeled "Match Line A11" so you'd know where to look for the adjacent area. Similarly, the match line on A11 would refer to A10.
    It's a good idea to put the match line itself in model space, so it carries over properly. Put it on its own layer so you can turn it on or off as needed. If you have a lot of plans, consider creating it as off by default. I like to give the match line a bit of width to make it stand out.
    breaking AutoCAD on a regular basis since 1991
  1. Need help with creating Site Plan from Deed Page
    By rodjos1000 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2016, 12:17 pm
  2. How do i overlay a topo plan and a site plan?
    By HollyRae in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2014, 10:02 pm
  3. Page Setup Resets To Portrait from Landscape in Sheet Set Page Setup Overrides DWT
    By Kapanther in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2010, 12:31 am
  4. Site plan and Block Plan
    By Lazer in forum Catch All
    Last Post: 16th Nov 2010, 06:22 pm
Tags for this Thread
