Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Toolbar sizing
  1. #11
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    311
    Thank's Dana W i had not checked into that.
  2. #12
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,797
    You can check your AutoDesk account download section for any hot fixes, but I am pretty sure the only retro hot fix is for AutoCad 2016 to Win 10.
    There are programs available that can run a virtual Win 7 OS for older software that will get you by, but I have not looked into any of them. Since I lease AutoCad, I simply update my version when I need to.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  3. #13
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,181
    The problem here is that your new laptop has a 4K monitor. AutoCAD did not have even minimal 4K support until a 2017 update.
    There are some adjustments you can make but none will clear up all the issues. I think you need to lower the screen resolution and keep text scaling below 150%. Plenty of more definitive information can be found over at the Autodesk forums on this.
    Drafting is a breeze.
  4. #14
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    G'day RobDraw,
    Mate, you have solved my problem.
    Thank you.
    I changed the settings to text scaling 125 and the resolution to 1920x1080 and it works properly.
    Kind regards,
    Neville
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,181
    I'm glad it worked for you.
  1. Replies: 1
    Last Post: 19th Sep 2010, 06:53 pm
  2. Lost Toolbar/adding macros to toolbar
    By gsksun4 in forum AutoCAD Beginners' Area
    Last Post: 25th Feb 2010, 03:07 pm
  3. Re-sizing an Array
    By Olhado_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Feb 2009, 12:25 pm
