Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    Civil
    Civil 3D 2016
    Nov 2016
    31
    Default Incompatibility Issues
    Hello
    We are a team of 10 guys working on Civil 3D surfaces and alignments
    So we recently sent our work to another guy for comments.
    Now the problem is this guy did all his comments but apparently he was using Civil 3D 2017 while we have 2015.
    Now we can no longer access the surface.
    Our work generally revolves around surfaces
    I have checked online but the solutions i have seen dont work and those which do( use of land xml) lead to loss of lots of man hours (5 months to be exact), since all the work has to be redone
    So is it possible to unlock the proxy entities locked by Civil 3D 2017 so that we can use it on Civil 3D 2015
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    This question seems specific to Civil3D so I have moved your thread to the Civil 3D & LDD Forum.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,154
    Apparently you can't restore the original drawing, so we'll proceed on that basis. The next option is to have Comment Guy save his copy down to 2015. From what I understand, though, the file format didn't change until 2018, so you should be able to open the drawing properly. Of course, "should" and "can" don't always intersect in AutoCAD.
    Another option is for Comment Guy to export the surface in LandXML format. You can then import the LandXML. Edit: sorry, didn't pick up on your remark about XML.
    Have you tried the Proxy Object Enablers? TrueView conversion? They never worked for me, but who knows.
    breaking AutoCAD on a regular basis since 1991
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    259
    Upgrade to 2017?
  5. #5
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,466
    Yeah, there is no going backwards in C3D, except for the 2016-2013 versions. We got spoiled when that was possible.
    You can LandXML out the surface, but of course that is the raw surface data, and you will lose any annotations, etc.
    There is a very clear warning when opening a pre-2017 drawing in 2017. Unfortunately, most users do not read warning dialogs these days.
    R.K. McSwain
    CAD Panacea | twitter
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    Following on from exporting to xml the surface, have had an instance where this method leaves a snail trail and in one case started to get lots of errors beacause the xml was saved on a local c: drive and not with the actual project on a server. Me personally I just display the surface mesh and export it, it makes 3dfaces then just read those into the surface. We read 3dfaces every day as its how we get supplied from one source our field data, this method has one advantage you can not screw up the surface by accidently modifying a point or breakline.
    We are about to go to 2018 and this is the sort of headache we dont need when providing to extrnal contractors and we are now going to full 3d machine control and a lot of these guys want say 2004 version of surfaces hence 3dfaces.
  7. #7
    Full Member
    Civil
    Civil 3D 2016
    Nov 2016
    31
    Hey
    I have tried exporting to land Xml
    The Problem is the drawing that gets exported still is locked and hence cant edit and save using a lower version
    From Civil 3D 2017- Export Civil 3D Drawing
    Drawing gets exported
    From Civil 3D 2015- Open the exported drawing and try to save. Drawing still cannot be saved and is locked...
  8. #8
    Full Member
    Civil
    Civil 3D 2016
    Nov 2016
    31
    Yeah I upgraded to 2017
    But I realised too late the backwards incompatibility
    All our clients and contractors use 2015 and below
    So now we are working on drawings which other parties cant edit, let alone save.......!
    So unfortunate
  9. #9
    Full Member
    Civil
    Civil 3D 2016
    Nov 2016
    31
    Yeah
    Unfortunately
  10. #10
    Windows 7 Pro x64
    HP ZBook 17
    16GB
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,466
    Quote Originally Posted by Alcapone001 View Post
    Hey
    The DWG file will be fine, once you get rid of the 2017 AEC objects. You can't just export them out and then open the drawing in pre-2017. The 2017 AEC objects will still be there.
    But it's a lot easier to just have all parties do the work in the same version.
    R.K. McSwain
  1. PDF Issues
    By CADnewbie in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2012, 04:28 pm
  2. MLeader incompatibility Issues
    By funk in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th May 2012, 02:22 pm
  3. Help with CAD/CAM Issues
    By Currahee in forum Autodesk Software General
    Last Post: 2nd Jul 2009, 02:25 pm
  4. ACAD 2009 Rendering issues...Autodesk claims Hardware issues
    By eric_monceaux in forum Hardware & Operating Systems
    Last Post: 22nd Jan 2009, 02:36 pm
