+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Junior Member chubster41's Avatar
    Using
    AutoCAD 2000
    Join Date
    May 2006
    Posts
    16
    Default Issue with my LTS
    Ok well I will try to explain this as clearly as possible...
    Ok I have an architectural bakground with some lines being dashed, that is being xref'd to my S2.3
    I xref it and I draw my stuff which some have to dashed, hidden etc. but with the LTS set to 48 the dashed architectural lines come out big. I changed my LTS to 1 and it got reversed, the arch. was good but mine wasnt.
    So at 1, arch is good mine isnt
    at 48 or any other number mine is good but the arch is bad..
    what could it be? any suggestions
    Ive attached a picture so you can see.
    The one on the left is at LTS 1
    on the right LTS 24
    the arch. backgrounds are the mustard and blueish color lines.
  2. #2
    Full Member vasqrainier's Avatar
    Using
    not applicable
    Join Date
    Sep 2006
    Posts
    63
    Default
    try this!
    under linetype manager, look for details and uncheck "Use paper space units for scaling" and regen.
    tell me if whats the outcome...
  3. #3
    Senior Member Groutie's Avatar
    Computer Details
    Groutie's Computer Details
    CPU:
    i7 3.6 GHz
    RAM:
    32Gb
    Graphics:
    Quadro 4000 2Gb
    Using
    AutoCAD 2013
    Join Date
    Jun 2006
    Location
    London
    Posts
    127
    Default
    OK. I've always had this problem with XREFS.
    I normally draw with LTSCALE 200 (command line) in MSPACE, then change to LTSCALE 7 (command line) when I'm in PSPACE for presentation. Fine on my drawings.
    If the base drawing you're XREF ing in has been drawn with a specified linetype scale (see attached) you have to try and match this. ie. dont' draw your detail using 1.00 (default). When you've set this, ALL entities will be drawn at this scale factor and will match the properties of those entities on the XREF. Architects seem to be the worst offenders BTW, most engineers use 1.0 then use LTSCALE to set what is seen on the drawing (PSPACE). Once you've matched the XREF linescale properties you've then got to fiddle with the LTSCALE (command line) to display the line dashes etc. at the desired size. Hope this helps
  4. #4
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    2,965
    Default
    Before you tear your hair out by the roots, there are two line style source files (acad.lin and acadiso.lin) which have a 25 times factor between them. A line style loaded from one file can be in the same drawing as a different line style loaded from the other file. So the first thing to do is to reload all line styles in the drawing from the same source file.
  5. #5
    Using
    AutoCAD 2000
    Join Date
    May 2006
    Posts
    16
    Smile
    Quote Originally Posted by Groutie View Post
    ok well changin the lts in the xref's worked....I just typed in MO and highlghted eveything and changed it
    thanks for the help peeps
Similar Threads
  1. Having an issue with XREF's....
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2006, 12:43 am
  2. Polyline Issue
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Sep 2006, 02:04 pm
  3. Maybe a small issue here!
    By fahim108 in forum Feedback
    Last Post: 17th Sep 2006, 10:13 am
  4. Layer issue
    By dclick in forum AutoCAD Beginners' Area
    Last Post: 27th Jun 2006, 08:52 pm
  5. Hatch Issue
    By CADken in forum AutoCAD General
    Last Post: 16th Jun 2006, 09:44 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
