Results 1 to 2 of 2
    Full Member
    SMP's Computer Details
    The Millennium Falcon
    Which One?
    Surveying
    SMP's Discipline Details
    Draftsmen
    Surveying
    A broad array of roles from Graphic Desgin to GIS and all points inbetween in terms of dealing with Land Geomatics.
    Civil 3D 2014
    Jan 2012
    Alberta, Canada
    94
    Default Motion Path Animations.
    hey all, It's been a good long while since i stopped in here.
    I am using Civil3D 2016 and i am trying to make a motion path animation and so far i have been successful in creating a path, and getting a camera to move along it in the preview of the motion path animation, however...
    nothing is being displayed or played back.
    I just want to have a path animation of a surface i have in the dwg. the surface is there, i have triangles on and to start i have chosen realistic for any option that requires a visual style.
    This is my first kick at the can at something like this so any good help would be appreciated.
    Let me know if you need more info.
    Cheers.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,155
    When you say "nothing is being displayed or played back," do you mean there is no video at all? When you give the command to animate, does it work for a while with no apparent result, or does it stop immediately?
    I can think of two possible issues. One, your video was generated, but you don't know where it is. There's a setting somewhere to specify the folder to put it. Two, the video was generated, but it's blank. That's probably because you need a light source, or at least one in the proper location at the proper strength. Without light, your camera is flying blind (pun intended). For a large civil surface, you'll probably want a sun instead of a lamp.
    breaking AutoCAD on a regular basis since 1991
  1. Create Motion Path Animations
    By stenews in forum AutoCAD General
    Last Post: 21st Sep 2011, 04:38 pm
  2. Motion Path in Z
    By FazBear in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Apr 2010, 08:38 pm
  3. Motion path animation with multiple paths?
    By darktrooper7 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Oct 2007, 01:06 am
  4. Replies: 0
    Last Post: 13th Jul 2007, 05:31 am
