Results 1 to 4 of 4
Thread: Point
    Junior Member
    AutoCAD 2016
    Jul 2016
    12
    Default Point
    I have received a survey with this type of points. I would like to know how from civil 2017 I can include it in an already created surface.
    Thank you
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,020
    This is real quick and dirty lisp code but matches your dwg. Makes new Autocad "points" then use the option "Add Drawing objects, Points" to merge into an existing surface. It can do with a bit of refinement if its to be used often.
    Code:
    (defun makepts ( / ss pt x)
    (setq ss (ssget (list(cons 0 "insert")(cons 8 "V-NODE")) )) ; a block on layer "V-node"
    (setq ent (assoc 10 (entget (ssname ss (setq x (- x 1)))))) ; insertion point in 3d
    (setq pt (list (cadr ent)(caddr ent)(cadddr ent)))
    (command "point" pt)
    (makepts)
    Junior Member
    AutoCAD 2016
    Jul 2016
    12
    Thank you BIGAL!!!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,020
    No worries very simple to do.
  1. Replies: 1
    Last Post: 29th Aug 2011, 10:00 pm
  2. Replies: 0
    Last Post: 29th Aug 2011, 09:52 pm
  3. Replies: 10
    Last Post: 9th Jun 2011, 04:57 pm
  4. Inventor Drawing dimensions point to point, aligned, curve
    By linnmaster in forum Autodesk Inventor
    Last Post: 8th Feb 2010, 07:29 am
  5. Replies: 9
    Last Post: 16th Oct 2009, 02:01 am
