Results 1 to 4 of 4
    Senior Member
    AutoCAD 2015
    Jan 2015
    126
    Default Force internal text for dimensions
    Hello, I have a question about dimension.
    I want to force the text to stay inside the dimension and not to get out if there isn't enough space. I can't find the option in dimstyle and I have to force it by change the voice "INTERNAL TEXT" in proprieties. I've to do that for every quote.. Do you know how to force it?
    Look at the gif to understand my question better
    Thank you! Dennis
    Senior Member
    AutoCAD 2016
    Jan 2012
    161
    Set System Variable DIMTIX to 1.
    AutoCAD 2013
    Nov 2011
    5,995
    Guran has nailed it, you can find this setting also on the Fit or Adatta (in your case) tab, in Options.
    Senior Member
    AutoCAD 2015
    Jan 2015
    126
    Quote Originally Posted by guran View Post
    Quote Originally Posted by Dadgad View Post
    Thank you guys!!!! I didn't see it in the "adatta" tab !
    and thanks guran for the advice, I'll use it in my lisp!
    Thanks!!
    Dennis
  1. Force dimensions to line up
    By xr309 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Feb 2014, 12:58 pm
  2. Mirroring a Block with internal text
    By clipper392 in forum AutoCAD Beginners' Area
    Last Post: 19th Apr 2012, 02:44 pm
  3. Change multiple Dimensions measured text into normal text?
    By apsonwane in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2011, 09:31 am
  4. why does ACAD Mech. force text onto TEXTS layer??
    By neeboy in forum Mechanical & MDT
    Last Post: 19th Oct 2010, 09:08 pm
  5. How can I force dimesion text orientation for aligned dims?
    By AlanRees in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2004, 12:08 pm
