Results 1 to 4 of 4
    Forum Newbie
    Education
    AutoCAD 2010
    Jul 2017
    1
    Default how to connect/joint them into close path.
    hi ! I have a Arc (blue) and a ellipse (yellow),now I want connect them into a close path (intend for use instruction like sweep or revolve) but I can't joint it anymore. What instruction I should do for connect/joint them ? Thanks.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    Well, the first issue is that you can't join an arc and an ellipse, but to make matters worse, it appears as though your arc and ellipse are in two different X,Y planes. You can't join objects that lie in different planes, so even if you change your PELLIPSE variable to 1 and then recreate the ellipse as a polyline, you still won't be able to join it with the arc.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    292
    You can use the free tool PEDIT3D - download from www.ant-ares.de
    Enjoy!
    Jochen
    Full Member jagwinn's Avatar
    jagwinn's Computer Details
    Win7PRO with Compatability Wizard immulating Win2000
    Gateway M7 Laptop
    Genuine Intel(R) CPU T2050 @ 1.60GHz
    2.00 GB
    111 GB HDD
    Mechanical
    jagwinn's Discipline Details
    Machine mechanic; wet chemical (soap and shampoo; aerosol)
    Mechanical
    Industrial Machine Repairman Packaging Machine Repairman
    AutoCAD 2000
    Oct 2009
    Bloomington-Normal, Illinois
    25
    Ecellant, scj!
    insert LIKE BUTTON here.
  1. Remove distance from each joint
    By CAD USER in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Oct 2016, 07:12 pm
  2. joint colinear polylines
    By trunglupin in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2014, 10:52 am
  3. joint
    By TonyBorland in forum Autodesk Inventor
    Last Post: 3rd Apr 2010, 03:28 pm
  4. Rolling joint: Belt
    By oZafin in forum Autodesk Inventor
    Last Post: 15th Jan 2009, 05:42 pm
  5. Getting smoothness at the joint
    By kanyakumari_t in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jan 2006, 03:09 pm
