Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2004
    Jul 2017
    Default Re-associating dimensions
    I accidentally made my main floor plan a block while working on other things in the model (did not toggle the "retain" and instead turned whole main floor into a block). Now the dimensions in paper space are no longer associated to the wall corners etc... Is there any easy way to go back and re-associate the dimensions without manually going snap by snap?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    steven-g's Discipline Details
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    I don't think so, from the sound of it, you had worked on the drawing for a while after mistakenly creating the block. So your only choice would be to redo the dimensions one at a time or keep pressing the undo button to get you back to a time before the dimensions lost their associativity but then lose any work you have added in that time. Or a combination of the two, copy any new details out into a new drawing. Undo Undo Undo in the original drawing to get the associativity back and then bring in the new details again. This does all depend on you not having closed the drawing at any point after losing associativity or undo will no longer help. Hopefully, someone will come along with a method to do it programmatically.
    Just a thought would the .bak file still have the plan with associative dims. Copy and rename the .bak file and then copy any new details into that drawing.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  1. Bulk Re-associating an EPD file?
    By Bryce M in forum MEP
    Last Post: 12th Sep 2012, 03:25 pm
  2. Drive feature dimensions with sketch dimensions?
    By Hickoz_bro in forum SolidWorks
    Last Post: 15th May 2011, 01:41 am
  3. Associating Menu Files w/ User Profile?
    By thicketman in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2009, 12:32 am
  4. Hatch un-associating itself
    By Jaxom in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2006, 07:21 pm
  5. Associating text/location and exporting/importing to excel
    By anonypuff in forum AutoCAD Beginners' Area
    Last Post: 8th Sep 2005, 01:23 am
