Results 1 to 4 of 4
    Senior Member
    gotchy's Computer Details
    XP Pro
    Intel DX68D8
    Intel i-5
    2 GB
    Nvidia Quadro 5500 1GB
    2 GB
    HP 2009M
    Mechanical
    gotchy's Discipline Details
    Tool Designer
    Mechanical
    Tool and Die designing and making. Also 3-D Tool design.
    AutoCAD 2000
    Oct 2009
    R.I.USA
    156
    Default Converting solid line to dotted line
    Hello,
    I have just been given a bunch of drawings to update and it looks to me like the person who made these drawings didn't know how to display hidden lines, in that all the holes in the drawings are represented with solid lines. I would like to know if there is a method by which I can change the solid lines to dotted lines by clicking on them, rather than re-drawing them all. I have to do this in AutoCAD 2000, if it matters at all. Heck of a way to "update", isn't it?
    Thanking you is,
    Andrew
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,209
    Rather than redrawing every hidden line, you could put them on a separate layer and assign the proper linetype to the layer. Less practical is changing the linetype property for each line--that makes them harder to manipulate, especially if you don't have the Select Similar command (which came out in 2011, it says here).
    breaking AutoCAD on a regular basis since 1991
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    Quote Originally Posted by gotchy View Post
    Hello,
    Thanking you is,
    Andrew
    also check match properties. matchprop i think it is. that will do what is in bold above.
    where did my sig go?
    Senior Member
    XP Pro
    Intel DX68D8
    Intel i-5
    2 GB
    2 GB
    HP 2009M
    Mechanical
    Tool Designer
    Mechanical
    AutoCAD 2000
    Oct 2009
    R.I.USA
    156
    Thank you Gentlemen!
  1. Changing Construction Line to Dotted Line
    By D1-Xen in forum AutoCAD General
    Last Post: 6th May 2014, 12:36 pm
  2. Change a continuous line to a dotted line
    By Brian in forum AutoCAD General
    Last Post: 1st Apr 2014, 11:35 pm
  3. How do I sketch a dotted line to represent a hidden line?
    By reggy in forum AutoCAD Beginners' Area
    Last Post: 11th Feb 2013, 08:16 pm
  4. Dotted Line help
    By waterdoc in forum AutoCAD Beginners' Area
    Last Post: 24th Nov 2009, 08:38 pm
  5. Drawing a dotted line..
    By JaketheMan in forum AutoCAD Beginners' Area
    Last Post: 23rd Feb 2009, 04:18 pm
