Rooster Posted July 4, 2017 Share Posted July 4, 2017 Since AutoCAD recently brought the TXT2MTXT command from Express Tools into main AutoCAD, and updated/improved it in the process, I can't get it to consistently do what I want. 1. Converted MTEXT justification seems very random. I have tree text on my drawing consisting of three separate elements of single-line text which I combine using TXT2MTXT. Most of the time the MTEXT justification is TopLeft (what I want), but I'm also getting some MTEXT (within the same drawing) with TopCentre and also TopRight justification. I am guessing that this is governed by the position of the first/top bit of text in relation to the others, but would be nice to default to TopLeft as the old command did. I now have to add in another step by selecting all and changing justification in Properties - not a big issue, but something I didn't have to do previously. 2. Line spacing of the MTEXT is also pretty random. I want it to default to 1, but again it varies widely within the drawing. I did look for and find a default setting somewhere for linespacing, but this didn't seem to make a difference. The Settings under TXT2MTXT don't give me too many options, and although I can force uniform linespacing, I can't define what that spacing is. Again, I'm having to add in another process afterwards by selecting all and changing the linespace value. 3. I can see the use of being able to combine existing bits of MTEXT with other MTEXT or single-line text with the new command, but for my workflow the way the old command worked was better - if I have a lot of trees all close together, obviously there is a lot of text there and being able to select 3 bits of single-line text to combine by using a crossing box without worrying that I may also be picking already-combined MTEXT was a quick way to work. Now I have to take much more care picking the exact 3 bits of text I want because otherwise it's combining them with text that I don't want it to. This has slowed me down a lot. So I guess I'm asking is whether there are any settings I should be looking at for governing MTEXT justification and linespacing, and whether there are any Lisps knocking around that did what the old TXT2MTXT did (ie. ignored existing MTEXT). Quote Link to comment Share on other sites More sharing options...
tombu Posted July 5, 2017 Share Posted July 5, 2017 Try Lee Mac's Text2MText Upgraded lisp function http://www.lee-mac.com/text2mtext.html Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 6, 2017 Author Share Posted July 6, 2017 Really appreciate the suggestion, Tombu. I am already familiar with LeeMac's lisp. The only reason I don't use it in this instance is that text has to be selected individually rather than by crossing box Quote Link to comment Share on other sites More sharing options...
tombu Posted July 6, 2017 Share Posted July 6, 2017 Try Kent Cooper's at http://cadtips.cadalyst.com/multiline-text/improved-text-mtext or anim8er_gie's at https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/looking-for-lsp-that-converts-text-to-mtext/m-p/2590489#M283755 or CAB's at http://forums.augi.com/showthread.php?68532-Help-with-TEXT&p=763362&viewfull=1#post763362 Google returns about 255,000 results, version you're looking for has been done I'm sure. Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 6, 2017 Author Share Posted July 6, 2017 Thanks again, Tombu. I have certainly trawled through Google myself, but yet to find anything suitable. Of the three you listed, one requires that you select each bit of text individually, and the other two just convert text to mtext without combining. I'll keep looking... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2017 Share Posted July 10, 2017 Express Tools is pretty much a collection of LISPs, you should be able to locate the TXT2MTXT from the Express tools somewhere. Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 11, 2017 Author Share Posted July 11, 2017 Thanks, SLW210 - the Express Tools TXT2MTXT is what I've been using. But AutoCAD recently updated this, making it 'cleverer' - now it's too clever for what I need. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 11, 2017 Share Posted July 11, 2017 I think he means an "older" version. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 11, 2017 Share Posted July 11, 2017 Yes, an older version of TXT2MTXT. I'll move this to the AutoLISP, Visual LISP & DCL Forum and maybe one of the LISP Gurus can come up with something to do it the way you like. Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 11, 2017 Author Share Posted July 11, 2017 Hope so. I did try the TXT2MTXT tool via the Express Tools menu, but it does the same as the updated version. I've searched for older versions of the command, but no luck Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 11, 2017 Share Posted July 11, 2017 Hope so. I did try the TXT2MTXT tool via the Express Tools menu, but it does the same as the updated version. I've searched for older versions of the command, but no luck In your travels did you find and check out the TXT2MTXT lisp routine from DotSoft? So you are 100% sure that the "old" TXT2MTXT (pre-2017 version) did exactly as you described in your first post (item #3)? What version of AutoCAD were you previously running? Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 11, 2017 Author Share Posted July 11, 2017 Thanks ReMark - I was using old TXT2MTXT in AC2016 and back as far as AC2010ish, probably. It was also working as I described with AC2017 until it got updated. I do have the DotSoft version - it's a sort of compromise between the old and new versions of TXT2MTXT as there are a couple of other steps involved in the command that I'd rather not have to confirm each time. But a slight improvement, nonetheless Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 11, 2017 Share Posted July 11, 2017 I checked the Express folder on a computer here that is running AutoCAD 2013. TXT2MTXT was not listed. Could it have been named differently or was it located in a different folder? Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 11, 2017 Author Share Posted July 11, 2017 No reason why it should be named anything other than txt2mtxt.lsp or stored in any other folder that I can think of... Unfortunately, I don't have any older versions of AC on my current PC to refer back to. Thanks for taking the time to look, though! Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 11, 2017 Author Share Posted July 11, 2017 (edited) Just found a lisp on this thread which at first glance might do what I need... http://www.cadtutor.net/forum/showthread.php?74154-Text-2-MText-Multiple-instances If at first you don't find, search & search again... Edited July 11, 2017 by Rooster Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 12, 2017 Share Posted July 12, 2017 The File in Express tools for TXT2MTXT is leaderex.arx. What options do you have selected in the TXT2MTXT options? (Just Right-Click while in the command to bring up options). Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 12, 2017 Author Share Posted July 12, 2017 I have: -Combine into a single mtext object (ticked) -Text ordering - sort top-down selected -Word-wrap (unticked) -Force uniform line spacing (ticked) Quote Link to comment Share on other sites More sharing options...
ronjonp Posted July 12, 2017 Share Posted July 12, 2017 I have:-Combine into a single mtext object (ticked) -Text ordering - sort top-down selected -Word-wrap (unticked) -Force uniform line spacing (ticked) Did my code work for you (from the link)? Sounds like a perfect fit. Quote Link to comment Share on other sites More sharing options...
Rooster Posted July 12, 2017 Author Share Posted July 12, 2017 Hi Ron - yes, seems to be just what I needed. In fact, an improvement on my previous workflow as this combines several groups of single-line text into mtext with one crossing selection, rather than picking each group individually. In the end, I'm glad AutoCAD messed with the TXT2MTXT command as it forced me to search for an alternative. Thanks for posting it! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted July 12, 2017 Share Posted July 12, 2017 Glad to hear Quote Link to comment Share on other sites More sharing options...
