Results 1 to 5 of 5
    Forum Newbie
    Manufacture
    AutoCAD LT 2018
    Jul 2017
    2
    Drawing Using Windows Search for Information Inside Drawings
    Hello,
    Is there a way of searching across a number of AutoCAD files for files containing particular text? This used to be possible in Windows XP, but does now not work in Windows 7 annoyingly. We have thousands of DWG files that have been drawn up over the past 20 years and to be able to search for a particular text string in a file would be hugely beneficial, such as part numbers and job numbers etc.
    We are running Windows 7 and AutoCAD 2018 LT.
    Can this be done with our current setup, or is there a another program we could use? I believe Autodesk Content Explorer used to serve this function, but has now been discontinued.
    Your help would be greatly appreciated.
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor 07lodgeT.
    When in doubt, check Lee Mac out.
    http://www.lee-mac.com/bfind.html
    Thanks Lee!
    Better yet, before you are in doubt, check out his incredible offerings preemptively.
    Whoops, you are using LT, no lisp!
    Do you have access to a non LT machine on which you could use this?
    Forum Newbie
    Manufacture
    AutoCAD LT 2018
    Jul 2017
    2
    Quote Originally Posted by Dadgad View Post
    Thanks Lee!
    Thanks for that, unfortunately Autocad LT doesn't support LISP or VB
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,705
    "FINDSTR" is for text files it is a Windows command line operating system option. There may be a binary version. Else you will need a compiled .net version of something like bfind.
    Findstr VLA *.lsp
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    There is a DwgSearch tool in DotSoft's ToolPac available at Dotsoft.com. Perhaps you can contact them to get just the DwgSearch function.
  1. Replies: 16
    Last Post: 17th Jan 2015, 08:05 am
  2. Using search in windows 7
    By BIGAL in forum Hardware & Operating Systems
    Last Post: 14th Jul 2012, 02:20 am
  3. Windows search layout tabs
    By ofishil in forum AutoCAD General
    Last Post: 3rd May 2011, 11:13 pm
  4. Search and replace inside string variable?
    By ajs in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th May 2009, 12:29 am
  5. Is it Possible to search for the text inside a Dwg file??...
    By sarabrajkumar in forum CAD Management
    Last Post: 24th Dec 2008, 12:31 pm
Tags for this Thread
