Results 1 to 5 of 5
    Senior Member
    gotchy's Computer Details
    XP Pro
    Intel DX68D8
    Intel i-5
    2 GB
    Nvidia Quadro 5500 1GB
    2 GB
    HP 2009M
    Mechanical
    gotchy's Discipline Details
    Tool Designer
    Mechanical
    Tool and Die designing and making. Also 3-D Tool design.
    AutoCAD 2000
    Oct 2009
    R.I.USA
    158
    Default Using the Match Properties tool in Autocad
    I would be grateful if one of the Gurus here would give me a step by step explaining the Match Properties tool in AutoCAD. I have enclosed a typical drawing, showing a center hole represented by solid lines, instead of dotted lines, as it should denote a 3/16" hole, in a tool-jaw. I am attempting to convert solid lines to dotted lines in existing drawings needing updating.
    Thank you,
    Andrew
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    If you want to use Match Properties then you need something in the drawing to match. Create a new layer for the dotted lines and then draw out a line in your drawing and put it on the dotted line layer. Then you can initiate the Match Properties command, select the dotted line as the "source object" and then click on whatever objects you want to inherit the objects properties.
    Here's a video that explains the process: https://www.youtube.com/watch?v=kDnNqw2hHSA
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Make sure your line type scale is not so large that ONE dash isn't bigger thsn your object, or so small that the line only LOOKS like it is solid.
    As long as the layer for the dashed lines will be made, simply select all the lines you wish to be dashed and then select that layer from the dropdown list. 2000 does have a layers tool bar, right?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Senior Member
    XP Pro
    Intel DX68D8
    Intel i-5
    2 GB
    2 GB
    HP 2009M
    Mechanical
    Tool Designer
    Mechanical
    AutoCAD 2000
    Oct 2009
    R.I.USA
    158
    Thank you for the input!
  5. #5
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    the commandline also often gives a good hint as to what is going on and/or what user input is required.
    E.G. for matchprop i expect it will say "Select source object" or something similar, then it might say "Select destination object" .
    where did my sig go?
  1. Match properties lisp for: dynamic block custom properties??
    By renzzzo in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Aug 2016, 01:48 pm
  2. Where is the Match Properties icon (paintbrush) on Autocad 2015 for Mac?
    By icad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Feb 2015, 03:52 pm
  3. Match Properties won't match Multileader Text in CAD 2010
    By Sengna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Sep 2013, 05:10 am
  4. how to match/change the global properties to match an object
    By vickilb in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Nov 2010, 02:10 pm
  5. AutoCAD 2009 - Rollover Tool Tips for Object Properties
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 28th Feb 2008, 01:56 pm
