Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Default Setting cui to load on Desktop shortcuts
    Instead of typing menu inside the cad environment and wait to load a specific cui layout, can i include this information on a shortcut somehow and have the appropriate cuiload by double clicking the shortcut?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Wouldn't having named workspaces work ?
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Nope i've been having a problem with a software called Carlson, that has its own menus, and when you launch it, it takes over, and then even launching plain Autocad still launches carlson menus and takes a hell of a time to load. And i have to type menu and load that acad.cui
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    826
    Quote Originally Posted by therock005 View Post
    Are you sure you started with a workspace with all the Carlson stuff removed? I would have expected that to work.
    Try starting with a profile that has all paths for Carlson removed along with the non-Carlson workspace.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  5. #5
    Senior Member
    Civil
    Aftertouch's Discipline Details
    Civil
    Engineer
    AutoCAD 2017
    Jul 2016
    Netherlands
    304
    Your shortcut is set to a profile.
    I got a custom profile that uses a 'Main enterprise'.
    This enterprice has the default ACAD.CUIX and my custom CUI as 'partialy loaded' files in them.
    that way i always have my custom CUIX, but still have the latast version of a ACAD.CUIX.
  6. #6
    Senior Member jonathann3891's Avatar
    jonathann3891's Computer Details
    Window 7 64 Bit
    Structural
    jonathann3891's Discipline Details
    Oil & Gas
    Structural
    AutoCAD 2012
    Dec 2008
    Houston, TX
    126
    Right click on your shortcut and look at the target. Add the path and profile name and if you want a certain workspace to load, you can add that too.
    Example:
    Code:
    "C:\Program Files\Autodesk\AutoCAD 2016\acad.exe" /p j:\cbicad\acad\CSA\A2k16\CSA.arg /w MyCSA /nologo
    CSA.arg is the profile
    MyCSA is the workspace
    Jonathan Norton
    Blog | Linkedin
  7. #7
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,595
    Carlson creates a profile. It's .EXE launches AutoCAD with this profile.
    From this point on, when you launch AutoCAD using the plain AutoCAD icon, it launches using the last used profile.
    So what you need to do is edit your AutoCAD icon to use the profile that you want to use, instead of the Carlson profile.
    R.K. McSwain
    CAD Panacea | twitter
  8. #8
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    826
    Reading your post again yes you can include this information on a shortcut and have the appropriate Profile and Workspace loaded by double clicking the shortcut. Make sure there are not any /b scripts or /ld ARX or DBX applications referencing Carlson in the shortcut.
    Command Line Switch Reference
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Copy your desktop Autocad Icon and change properties much safer, just end up with a couple of icons that will start Autocad.
  10. #10
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Quote Originally Posted by rkmcswain View Post
    And where are that profiles located? Which one is the autocad and which the carlson profile, so i can reference to each their own
  1. auto load style setting codes
    By blueshake in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Oct 2010, 01:10 pm
  2. Shortcuts...
    By danpooler in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Aug 2008, 07:15 am
  3. Setting a global plot setting
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 15th May 2008, 01:28 am
  4. Anyway to Re-Load & Un-Load Xrefs by Picking?
    By pjb84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Aug 2007, 09:39 pm
  5. Partial Load In Land Desktop 2005
    By VERYCIVILDRAFTER in forum AutoCAD Drawing Management & Output
    Last Post: 5th May 2006, 04:19 pm
