+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Full Member
    Using
    AutoCAD 2000
    Join Date
    Jan 2009
    Posts
    92
    Default Setting the Base Angle in DraftSight
    Hi - Using Draftsight in place of AC2000 I am having problems in re-defining the base angle for the purpose of dividing a circle from zero (i.e. 3 O'Clock position) to one of 45 degrees. In AC2000 I do this by selecting Snap/Settings/Angle and change the value from 0 to 45 which has the desired effect. Using DraftSight and selecting Drawing Settings/Unit System/Base Angle and changing the value from O to 45 which I would have thought would be the equivalent action does not have the same effect. Where am I going wrong?
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,612
    Default
    Strange but the method you describe seems to work for me. Did you click on the Apply button after making your change?
  3. #3
    Full Member
    Using
    AutoCAD 2000
    Join Date
    Jan 2009
    Posts
    92
    Default
    Hi Remark - Thanks for you repy. Yes, I have hit the "Apply" tab but without the required result.
  4. #4
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,612
    Default
    Well let me do a second test. How about a base angle of 117.356?
    OK...test done. That worked too. To check I draw a line and specify @6<0. The line however is drawn at an angle which equates to 117.356 yet when I check the properties of the line it says angle in XY plane = 0. That's what you are trying to achieve right?
    BTW...I can double check what angle the line is drawn at if the base angle is reset to its default of 0. Turns out the angle is 117.356 degrees.
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,612
    Default
    Step 1: set base angle.
    Step 2: draw line, check properties.
  6. #6
    Full Member
    Using
    AutoCAD 2000
    Join Date
    Jan 2009
    Posts
    92
    Default
    I wish to be able to simulate the drilling of 4 holes represented in the drawing by Points on a pcd starting with the base angle set to 45 degrees i.e the first Point or 'hole' to be at the NE position. My test so far has been to draw a circle of any diameter, select DIV/4 and expect to see the resulting points in the 45/135/225/315 locations whereas despsite reseting the base ange to 45 the four points are being drawn at 0/9/180/270. - Hope this helps.
  7. #7
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,612
    Default
    You could always resort to using Polar Tracking or set SNAPANG to 45.
  8. #8
    Full Member
    Using
    AutoCAD 2000
    Join Date
    Jan 2009
    Posts
    92
    Default
    Yes perhaps - but then why should the re-setting of the base angle approach work using AC200 and not in Draftsight?
  9. #9
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,612
    Default
    It does work...in both. Just not for you. Rest assured I test before I post.
Similar Threads
  1. Setting BASE ANGLE to North - Does not appear to work?
    By Tempest in forum AutoCAD Beginners' Area
    Last Post: 29th Apr 2015, 04:33 pm
  2. DraftSight: help drawing rectangle at an angle
    By iii76 in forum Design Software
    Last Post: 3rd Oct 2011, 03:21 pm
  3. Line will not angle in DraftSight?
    By Shiro in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2010, 12:22 am
  4. VB Automation - Setting the drawing base angle ?
    By chill in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Apr 2008, 09:30 pm
  5. Setting base angle 0d00'00" to an arbitrary line ?
    By bledking in forum AutoCAD Beginners' Area
    Last Post: 10th Dec 2007, 08:43 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
