Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Classic to 3D
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Default Classic to 3D
    Am I able to maintain my "Classic" screen setup ie: menu bars & pulldowns etc and have 3D availability?
    Kind regards,
    Neville
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    YES
    You have to look at creating your own menus and set up a workspace, we run this now with everyone having their own workspace.
    As an example I run CIV3D but my workspace is set up as drafting but I have a couple of pull down menus where I have taken the CIV3d commands and grouped them into a menu.
    AutoCAD 2013
    Nov 2011
    6,051
    Unless I am not reading you correctly, all you need to do is go into Modelspace and choose an isometric perspective, as it better displays modeling input, bingo start modeling. You probably also want to open your Modeling and Solid Editing toolbars. Those would be the appropriate toolbars if you are working with 3D Solids, you would choose others for working with surfaces or meshes. Then you can use the Workspace Settings icon, and save any changes you may have made, and name it 3D Modeling ala me, or anything you want.
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Thanks BigAl I will give it a try over the weekend but I may need a little guidance.
    Dadgad I have previously done it that way but "Classic" appears to only allow 2D.
    Kind regards,
    Neville
  5. #5
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by Neville Jukes View Post
    Kind regards,
    Neville
    I find that very hard to believe.
    Which is not to say, nor imply, that it is incorrect.
    If you click on your Modelspace tab, then set an Isometric view, what happens?
    I assume that you are not trying to do this through a locked paperspace viewport, as that would not allow you to change the view perspective, without first unlocking the viewport?
  6. #6
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    G'day Dadgad,
    Mate, I predominately work in model space so, no, I wasn't trying to do it in a locked paperspace viewport.
    I used to be able to do it in 2010 but when my computer died I loaded 2013 and it doesn't respond the same.
    However if I try to set it to 3D all my menu bars etc change!
    Kind regards,
    Neville
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    I think you missed what Dadgad was suggesting you can open any toolbar in a workspace. I opened Modelling as a test using 2013. As a shortcut type "-toolbar Modeling Show"
    Here is the source for the Surfal.mnu its just a text file just do CUI and copy and paste the commands out into your menu.
    Code:
    ***MENUGROUP=SURFAL
    ***POP15
    **SURFALIGN
    [Surfalign]
    [SURFACES]
    [Create Surface]^c^c_AeccCreateSurface
    [Create Surface from DEM]^c^c_AeccCreateSurfaceGridFromDEM
    [Create Surface from TIN]^c^c_AeccCreateSurfaceFromTIN
    [->Edit Surface]
    [Edit Surface Style...]^c^c_AeccEditSurfaceStyle
    [Edit Surface Properties]^c^c_AeccEditSurfaceProperties
    [Add Line]^C^C_AeccAddSurfaceLine
    [Delete Line]^c^c_AeccDeleteSurfaceLine
    [Swap Edge]^c^c_AeccEditSurfaceSwapEdge
    [Add Point]^c^c_AddPointToSurface
    [Delete Point]^c^c_AeccDeleteSurfacePoint
    [Modify Point]^c^c_AeccEditSurfacePoint
    [Move Point]^C^C_AeccMoveSurfacePoint
    [Minimize Flat Areas]^c^c_AeccMinimizeSurfaceFlatAreas
    [Raise/Lower Surface]^c^c_AeccRaiseLowerSurface
    [Paste Surface...]^c^c_AeccEditSurfacePaste
    [Add Boundaries]^c^c_AeccAddSurfaceBoundaries
    [Smooth Surface]^c^c_AeccSmoothSurface
    [<-Simplify Surface]^c^c_AeccSimplifySurface
    [->Add Surface Labels]^c^c_AeccAddSurfaceLabels
    [Add slope Surf Labels]^c^c_AeccAddSurfaceSlopeLabel
    [Spot Elevation]^c^c_AeccAddSurfaceSpotElevLabel
    [Spot Elevations on Grid]^c^c_AeccAddSpotElevLabelsOnGrid
    [Contour - Single]^c^c_AeccAddContourLabelingSingle
    [Contour - Multiple]^c^c_AeccAddContourLabeling
    [Contour Multiple at Interval]^c^c_AeccAddContourLabelingGroup
    [<-Add legend table]^c^_AeccAddSurfaceLegendTable
    [->Utilities]
    [Export to DEM]^c^c_AeccSurfaceExportToDem
    [Volumes Dashboard]^C^C_AeccVolumesDashboard
    [Water Drop...]^c^c_AeccCreateSurfaceWaterDrop
    [Catchment Area]^c^c_AeccCatchmentArea
    [Check for Contour Problems]^c^c_AeccCheckForContourProblems
    [Drape Image]^c^c_AeccDrapeImage
    [Extract Objects From Surface]^c^c_AeccSurfaceExtractObjects
    [Move Blocks to Surface]^c^c_AeccMoveBlocksToSurface
    [Move Blocks to Attribute Elevation]^c^c_AeccMOVEBLOCKSTOATTRIBELEV
    [<-Move Text to Elevation]^c^c_AeccMoveTextToElevation
    [ALIGNMENTS]
    [Create Alignment by Layout]^c^c_AeccCreateAlignmentLayout
    [Create Alignment from Polyline]^c^c_AeccCreateAlignmentEntities
    [Edit Alignment Geometry]^C^C^p_AeccEditAlignment
    [Reverse Alignment Direction]^c^c_AeccReverseAlignDirection
    [Design Criteria Editor]^C^c_AeccDesignCriteriaEditor
    [Offset lines]^c^cOffsetfeature
    [->Add Alignment Labels]^c^c_AeccAddAlignLabels
    [Add/Edit Station Labels]^c^c_AeccEditAlignmentLabels
    [Station/Offset]^c^c_AeccAddAlignOffXYLbl
    [Single Segment]^c^c_AeccAddAlignSegLbl
    [Multiple Segment]^c^c_AeccAddAlignSegLbls
    [Point of Intersection]^c^c_AeccAddAlignPointOfIntLbl
    [<-Multiple Point of Intersection]^c^c_AeccAddAlignPointOfIntLbls
    [->Add Tables]
    [Add Line...]^c^c_AeccAddAlignmentLineTable
    [Add Curve...]^c^c_AeccAddAlignmentCurveTable
    [Add Spiral...]^c^c_AeccAddAlignmentSpiralTable
    [Add Segments]^c^c_AeccAddAlignmentSegmentTable
    [<-Renumber Tags]^c^c_AeccEditTagNumbers
    [POINTS]
    [Create pts]^c^c_AeccCreatePoints
    [Add 1 PT]^C^C_AeccCreatePointManual
    [Pt on Surface]^C^C_AeccCreatePointRandomPoints
    [Add PT Table]^C^C_AeccAddPointTable
  8. #8
    AutoCAD 2013
    Nov 2011
    6,051
    G'day Dadgad,
    Kind regards,
    Neville
    Due diligence. In order to help you more efficiently. Modelspace is already 3D. If you want to keep the toolbars and workspace settings with which you are familiar and comfortable, and work in 3D, just start doing it, there is no NEED to change to the 3D Workspace. I suspect that most folks have a customized 3D workspace set up, as do I, which displays all of the toolbars which I like to use specifically for modeling. Bottomline the 3D workspace is the exact same workspace as the 2D workspace, with the only difference being the designated selection and possibly layout of the toolbars for different types of activities, such as annotation versus modeling. As I previously suggested, I personally prefer modeling in an Isometric perspective, because you can see what you are doing across the X,Y & Z axii simultaneously, unlike in an Orthographic perspective. But it still happens in the same modelspace as all other work.
  9. #9
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    I get all that & I can draw 3D models, however I can only draw 2D lines.
    See screenshot.
  10. #10
    AutoCAD 2013
    Nov 2011
    6,051
    See screenshot.
    Do you usually use Dynamic UCS?
    What is your UCSFOLLOW system variable set to?
    Might your OSNAPZ variable be set to <1>?
    If it is set to <1>, try changing it to <0>.
    What is your UCSDETECT variable setting?
    If it is 0 try switching it to 1.
    Are you saying that we are looking at a 3D Solid, or a 2D representation of one?
    Looks can be deceiving.
    Are you at liberty to upload the .dwg, that would really speed things up.
  1. workspace: MAP classic
    By cat3appr in forum Map 3D
    Last Post: 26th Apr 2017, 09:27 pm
  2. Classic interface
    By Ski_Me in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd May 2013, 05:50 pm
  3. Classic Layer
    By happyunited in forum AutoCAD General
    Last Post: 14th Jun 2010, 11:41 am
  4. 3d Classic workspace
    By Organic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2009, 10:05 pm
  5. Classic GDS?
    By captainm in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Apr 2008, 01:57 pm
