Results 1 to 2 of 2
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,281
    Default Monochrome Plot Style Still Prints Colors
    I decided to try one of the built-in templates for a project this morning and it uses STB files for printing instead of CTB files. I have two layout tabs and when I try to print one I select the monochrome.stb for the plot style table. All looks well except my dimensions which I use a color scheme a client prefers which has the text set to Cyan color. I'm using my Bluebeam PDF driver and the drawing looks find but the text is all in color, not black and white like I'm expecting. I tried the built-in AutoCAD PDF driver too but the results are the same. I thought monochrome meant no colors in the prints. So what am I doing wrong?
    It's deja vu, all over again.
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,281
    Okay, I found the CONVERTPSTYLES which removed all the named plot styles from the file. That resolved it. But this was definitely new territory for me.
  1. Colors for plot styles missing in Plot Style Table Editor - AutoCAD 2015 MAC
    By eisofia in forum AutoCAD Drawing Management & Output
    Last Post: 15th Apr 2015, 02:39 pm
  2. Change plot style table from none to monochrome in one hit
    By mdbdesign in forum AutoCAD General
    Last Post: 4th Mar 2011, 09:37 pm
  3. Where can I get the monochrome.ctb plot style table from. I only have monochrome.stb
    By rjnhouses in forum AutoCAD Drawing Management & Output
    Last Post: 5th Dec 2007, 07:55 pm
  4. ctb plot style black and white prints color
    By BITDRAUGHTY in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2007, 02:26 pm
  5. Pantone colors and plot style modification
    By hyposmurf in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2004, 02:12 pm
