Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Senior Member
    nicolas's Computer Details
    Windows 7
    Intel Dual Core 64 Bits
    2 GB
    AutoCAD 2015
    Jan 2008
    Rose Hill, Republic of Mauritius
    419
    Default Non-Orthogonal WC and Bathroom
    Hi to all.
    Have a non-orthogonal WC/Bathroom and I have to fix Shower, WC, Washing Machine and Wash Hand Basin into it. Any help will be most welcomed especially from someone who has actually done this.
    Non-Ortho WC-Bathroom.pdf
    Thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    What you have shown so far seems reasonable however...
    Is the washbasin going to be located against the exterior wall in a long vanity cabinet?
    Why do you need three windows in a bathroom?
    Why is the wall for the bathroom that forms one side of the passage thinner than the other walls?
    BTW...is that a walk-in shower?
    One of the problems I see is that you have a fixture that requires a water supply and a drain/sewer connection on each of the four walls.
    Any chance you can move one of the windows to the end of the passageway? At least you would have some natural light in an otherwise dark hallway.
    Can the door to the bathroom be relocated?
    Well here are my suggestions for what it's worth.
    Move one window to the end of the passage way. Relocate the door to the bathroom on the short wall to the left that meets up with the exterior wall. Keeping the washing machine on the same wall as you have it now install a corner shower (one with a 45 degree face on it) in the corner formed by the walls for the passage and the kitchen. Put a small vanity cabinet with sink and the WC on the wall that backs up to the kitchen. Now three of the four fixtures are in a straight line and will be easier to pipe up. And if you eliminate one window and relocate the other two then that small triangular space at the top of the room can be utilized for a storage area. I'd also change the thickness of the wall that the door to the bathroom is located in to match the others.
    After a closer look relocating the door may not be possible since the wall length looks to be shorter than the width of the door. Any chance an adjustment of some kind could be made to accommodate the door?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,877
    What program will you be using to accomplish this task?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Here is a rough idea of what I had in mind. I made the passage wall thicker, moved the door, eliminated one window and rearranged the fixtures.
    If the washing machine comes with a stackable dryer you can easily vent through the exterior wall.
  5. #5
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    419
    Smile
    Remark,
    Thank you very much. I believe your proposal is a much better and more optimal one. I have canceled one of the window and have a riser instead to cater for the various pipes. Attached is the revised layout with a quick 3D for the overall project (not yet revised).
    MARION 01c [20170712].pdf
    Again many thanks for your inputs.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Why didn't you increase the width of the passage wall?
    Wouldn't the wall between the bathroom and the kitchen be wider to accommodate the necessary piping for the bathroom fixtures? I don't fully understand what you did. In the U.S. the interior walls would normally be framed out using 2x4's except for the bathroom where the plumbing would require a 2x6 wall.
  7. #7
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    419
    The wall are made up of concrete cellular blocks (inner and outer walls). All the walls are made up of 200mm due to large span and provision for additional 2-3 floors in the future. The walls for the wc/bathroom is a partition walls, again, concrete cellular wall of 100mm and does not carry any loads. The whole construction lays on a Reinforced Concrete Frame made up of pad footings, Columns, Beams and Slab. The outer walls are load-bearing walls and helpers to the RC Columns, as they are laid prior to casting of slab.
    Attached is the latest layout (2D).
  8. #8
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    703
    Something you may not have considered.
    Here in the UK it is very unusual to have a washing machine in a bathroom.
    If no utility room is available then it is more often located in the kitchen, under a work surface on an external wall.
    There are historical reasons for this - washing clothes uses hot water, in the days before mains water and electricity hot water was only readily available in the kitchen.
    But the main reason these days is that electrical outlet sockets are not normally fitted in bathrooms for safety reasons.
    Usually the only outlet socket you will find in a UK bathroom is an electric razor socket, at a relativly high level above the floor.
    Everything else electrical in a bathroom, lights, showers, body driers, etc., is hard wired with water resistant fittings.
    *** Out of Beer Error ->-> Recovering Memory***
  9. #9
    Senior Member
    Windows 7
    2 GB
    AutoCAD 2015
    Jan 2008
    419
    Nukecad,
    Very good input regarding electrical security. I have not thought of this.
    Thanks you very much for this.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    I've actually seen houses, here in the U.S., where the washing machine and dryer are located in a bathroom. They may be hidden in a closet area behind folding doors. Given the shower and sink will require hot water having the washing machine in the bathroom poses no additional problems.
    We rented a house on the island of St. John's that had a stackable, front loading, washer and dryer in a closet in the bedroom. The back wall was shared with the master math.
  1. VIEWBASE and non-orthogonal parts
    By nestly in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Nov 2014, 07:52 pm
  2. Orthogonal Best Fit Plane
    By Hippe013 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2011, 12:26 am
  3. Orthogonal polyline lisp....a little help here
    By Utah_Indie in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2010, 04:07 pm
  4. Creating non-orthogonal 3D
    By didko in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Aug 2008, 03:46 pm
  5. Problem with orthogonal not following UCS
    By robert1 in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jun 2006, 07:03 am
