Results 1 to 6 of 6
    Forum Newbie
    AutoCAD LT 2017
    Jul 2017
    Malaysia
    3
    Default Delete Overlapping Circle
    Hi,
    I am using AutoCAD LT 2017 for my design. I found that the overkill command only can be used to delete overlapping lines, polylines and arc.
    If I have overlapping circle in my design, how do I can delete the overlapping?
    Thanks in advance
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,952
    I have moved your thread to the AutoCAD LT Forum.
    The OVERKILL in Full 2011 AutoCAD Express Tools deletes circles, if the new command in AutoCAD LT doesn't, you may be stuck doing them manually, since you can't use LISP.
    Can you post the drawing?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Nini: When you say "overlapping" do you mean you have two circles of the same size one sitting exactly over the top of the other?
    If that is the case then there should be no reason why Overkill whould fail to delete the duplicate circle unless you did something unusual. I know because I tested the command using AutoCAD LT 2014.
    Forum Newbie
    AutoCAD LT 2017
    Jul 2017
    Malaysia
    3
    Hi ReMark,
    After I zoom in the drawing, the circle is not overlapping at the same place. There was ~0.01mm space between the circles. I think that was the cause i cannot use the overkill command because when I try to overlap the circle at exactly the same place, the command works well.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    That's why overkill has a tolerance value, there is just no way to decide which of the objects are to be deleted, so you could end up with problems further on.
    I've just been down graded from 2012LT to full Autocad 2017. I WANT LT BACK
  6. #6
    Forum Newbie
    AutoCAD LT 2017
    Jul 2017
    Malaysia
    3
    Quote Originally Posted by steven-g View Post
    Yes, now I understand. After playing a while with the tolerance value, the circle can be deleted. Now, my overkill command works well
  1. Replies: 3
    Last Post: 4th Sep 2014, 05:33 pm
  2. How to identify and delete overlapping objects
    By RRS1987 in forum AutoCAD Beginners' Area
    Last Post: 17th Oct 2011, 01:50 pm
  3. Help...delete texts overlapping
    By tieptouch in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Aug 2011, 08:21 am
  4. circle center line(Like Plus symbol and after circle 4 sides 5mm extra length)
    By johnpieter in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Dec 2010, 02:23 pm
  5. Help Needed-delete overlapping line
    By deejay500sl in forum AutoCAD Beginners' Area
    Last Post: 25th Apr 2010, 10:22 pm
