Results 1 to 5 of 5
    Forum Newbie
    Architectural
    AutoCAD 2017
    Jul 2017
    1
    Default Display of Dimensions
    Dear All,
    May I ask how to display the dimensions (in orange) as shown in the attached image on auto cad 2017 MAC version please?
    A new beginner here...
    Thank you very much for all your help in advance!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,863
    Wouldn't it be similar to AutoCAD on a PC?
    Linear dimension for the horizontal and vertical dimensions.
    Angular dimension for the 30 deg on the circle and Aligned dimension for the radius point to center of the circle dimension.
    There is one thing you shouldn't do however and that is have an extension line overlaying the geometry being dimensioned. I refer specifically to the dimensions 50, 200 and 30 (horizontal). The extensions lines on one side should be turned off.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,206
    If this is more than an exercise, you'll need to provide the radii of the two circles. It might make the dimension lines more distinct if you increase the offset distance.
    You can follow ReMark's advice or use Horizontal and Vertical type dimensions or Rotated. All have their advantages and disadvantages.
    breaking AutoCAD on a regular basis since 1991
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,577
    Your next step should be to look at DIMSTYLE this sets up how the dimension will look, things like precision do you want 30 or 30.0, arrows or other type of ends. As mentioned the offset gap between the dim lines and the object can be set.
  5. #5
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Or use the DIMROTATED command.
  1. Can't display dimensions
    By Reebs in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Mar 2016, 11:54 pm
  2. How do I control display of dimensions?
    By Vagulus in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Jul 2013, 06:25 am
  3. Dimensions display only when object is not a standard width.
    By Fett2oo5 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Oct 2012, 03:49 am
  4. How can I determine the display size of dimensions?
    By bgood2go in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Jul 2012, 04:40 pm
  5. Display Object Dimensions
    By steve8679 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2008, 03:30 pm
