Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    when autocad drawing was last saved with educetional version of autocad , a warning is popup when opening the drawing, this dialog box is enxpected by your program
  2. #12
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    this file were produced by educetional version
  3. #13
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    Quote Originally Posted by samifox View Post
    In this file I do not see a problem.
    Attach a picture.
  4. #14
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    Quote Originally Posted by maratovich View Post
    Attach a picture.
    im using 2010,
    and using ?
  5. #15
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    I'm using 2014.
    I still do not know how to suppress the window when opening it.
  6. #16
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    I'm using 2014.
    you dont. the only thing you can do to suppress this massage is to convert the archive with TrueView 2016+.
  7. #17
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    No. Necessary:
    -open .dwg
    -save as .dxf
    -open .dxf and save as .dwg
    Then this record will not be.
    But this must be done by hand.
  8. #18
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    No. Necessary:
    -open .dwg
    -save as .dxf
    have you tried that?
  9. #19
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    Why do not you believe us?
    Of course we did.
  10. #20
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    Of course we did.
    its being long time ago i investigate after that stamp and the only solution was to convert.
    glade to know there is another way
  1. Archive layout tabs within .dwg?
    By jmg5786 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2014, 01:44 pm
  2. How to use the LISP routines in this archive
    By CADTutor in forum Application Archive
    Last Post: 5th Jul 2010, 02:57 pm
  3. AutoLISP Archive Clean-up
    By Lee Mac in forum Feedback
    Last Post: 17th Jun 2009, 02:01 pm
  4. AutoLISP Archive
    Last Post: 17th Dec 2008, 11:55 pm
