Results 1 to 5 of 5
    Forum Newbie
    AutoCAD LT 2012
    Jul 2015
    2
    Default Problem when plotting with transparency
    Hi people, I am having a problem when plotting .PLT files.
    Just wondering if someone had the same problem, and a solution for it. I am using AutoCAD LT 2012.
    When I plot with transparency box ticked, the result file is displaced, and doesn't respect the defined area. I attached examples, the same file, plotted with transparency ON and OFF.
    When plotting PDF, the files are perfect.
    Thank you in advance!!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,581
    Why even plot to PLT thats a very old output that was aimed originally for pen plotters because of the time taken to do a plot.
    Forum Newbie
    AutoCAD LT 2012
    Jul 2015
    2
    It's a client demand, guess the print shops here in Brazil work better with that kind of file.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    813
    As I understand it plotting with transparency on converts it to an image file which greatly increases the size of the file while reducing the quality of the linework.
    Not familiar with your issue as I've never plotted to a PLT, but I'd avoid using transparency as much as possible. A fine ANSI31 hatch with the lineweight set to 0 looks just like solid transparency.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,581
    What printer are you using for the plt
  1. Transparency plotting vers Pin width plotting
    By muck in forum AutoCAD General
    Last Post: 20th Feb 2015, 01:28 pm
  2. Plotting with Transparency problems !!!!!!!
    By coggs in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Feb 2012, 04:45 pm
  3. Autocad Architecture 3D - transparency problem
    By Pawel in forum Architecture & ADT
    Last Post: 2nd May 2008, 12:51 pm
  4. 3d problem with transparency
    By starving in forum AutoCAD Beginners' Area
    Last Post: 13th May 2007, 09:59 pm
  5. problem with plotting
    By copernico84 in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2007, 02:11 pm
Tags for this Thread
