Results 1 to 5 of 5
    Forum Newbie
    Civil
    Civil 3D 2015
    Oct 2016
    2
    Default Move a line parallel to the nearest point of an arc.
    I have a line that I need to copy parallel to the closest point on an arc. How do I accomplish this? Thanks for your help.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    I presume that you have tried the OSnaps and are dissatisfied with the result.
    I would draw a temporary line, perpendicular from the line to the Centre of the arc. Where this line intersects the arc is the required point through which you could offset the line.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,217
    Welcome to CAD Tutor!
    If eldon's solution doesn't match your problem, please provide more information. If you don't know about the object snaps for Tangent and Perpendicular, you might want to look into them first (as eldon suggests).
    breaking AutoCAD on a regular basis since 1991
    Forum Newbie
    Civil
    Civil 3D 2015
    Oct 2016
    2
    I have a line where the face of my building is. There is a building setback line in front of it that is not radial to that line. I need to move the line at the face of my building to a point on the arc that is closest to the building. How do I move the line to the closest point of the arc?
  5. #5
    Windows 10
    Architectural
    Civil Drafter
    Architectural
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,217
    Quote Originally Posted by tmelkunas View Post
    I would use eldon's strategy. Draw a construction line from the center of the arc to the perpendicular point on the building face. Where that line intersects the arc is the nearest point. Move some point on your building to the intersection. If that is the setback line, you're done. If not, you can offset the the line by the setback width to get the final location. Finally, erase the construction line. All you have to do is finish drawing the building.
  1. lisp to move text from it's insertion point to the nearest line endpoint
    By poffenberger in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jul 2017, 03:38 am
  2. Nearest point on extend poly line from a given point
    By wimal in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2017, 01:03 pm
  3. Move text items to (an offset of) the nearest line
    By Simon1976 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2016, 06:54 pm
  4. Mass Move Blocks to Nearest Line
    By Ohnoto in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Mar 2016, 04:02 pm
  5. Insert Block, Angle and Move to nearest Line
    Last Post: 9th Mar 2016, 06:23 pm
