Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Drawing Limits
    Senior Member
    AutoCAD 2010
    Jun 2012
    391
    Default Drawing Limits
    Hello everybody,
    I have a set of about 1000 points covered in the window given in the code below with which I am trying to draw them in my drawing area. I find that they do not appear unless I Zoom Extent again. And when they appear the coordinates that appear are outside the limits.
    Can someone help me to get the points on screen without zooming again.
    Code:
    (defun C:drawpoints ( / list1 pt1)
      (setq p1 '(3800.00 1000.0) p2 '(4400.0 1300.0))
      (command "limits" p1 p2)
      (command "zoom" "E")
    (setq list1 pl
            pt1 (car list1))
      (while (/= pt1 nil)
        (setq pt1 (car list1))
        (command "point" pt1)
        (setq list1 (cdr list1))
    Thanks in advance
    Super Member
    not applicable
    Jun 2016
    606
    Do you want to move the points so that they fall inside the limits? Or do you want to change the limits to match the extents of the points?
    BricsCAD 18
    Super Member Commandobill's Avatar
    AutoCAD 2014
    Oct 2008
    Raleigh, NC
    538
    Your limits are nowhere near your points...
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
    Senior Member
    AutoCAD 2010
    Jun 2012
    391
    Roy_043,
    Yes I want the points to be displayed without Zoom Extent being invoked as I find my programs will not work inside this extent. Actually I have made a mistake in the limits. It is being corrected as follows:
    Code:
      (setq p1 '(163800.00 91000.0) p2 '(164400.0 91300.0))
    (setq list1 pl
            pt1 (car list1))
      (while (/= pt1 nil)
  5. #5
    Senior Member
    AutoCAD 2010
    Jun 2012
    391
    Commandobill,
    Sorry I have made a mistake in giving the limits. It has been corrected in post #4.
    Thanks
    Aloy
  6. #6
    Super Member
    not applicable
    Jun 2016
    606
    The rectangle defined by your limits measures 69400 x 300. Are you sure this is correct?
    Why not simply use:
    Code:
    (foreach pt pl
      (command "_.point" "_non" pt)
    (command "_.zoom" "_extents")
    BricsCAD 18
  7. #7
    Senior Member
    AutoCAD 2010
    Jun 2012
    391
    Roy_043,
    Sorry my mistake again. The rectangle is 600x300 and it has been corrected in my previous post. Is there no way to avoid Zoom Extent?. I tried setting limits. But I am not able to get the griddisplay correctly. It appears to me when Zoom Extent is done the coordinate system doesn't work correctly and a certain program I use gives me errors.
    Regards,
    Aloy
  8. #8
    Junior Member 1958's Avatar
    1958's Computer Details
    W7
    Surveying
    AutoCAD 2007
    Nov 2015
    Uzbekistan, Tashkent
    12
    Why not simply use:
    Code:
     (vl-cmdf "_.zoom"
              "_w"
              (getvar "extmax")
              (getvar "extmin")
  9. #9
    Senior Member
    AutoCAD 2010
    Jun 2012
    391
    1958,
    Yes it draws points and zoom to the extent and bring all my points to the screen, but doesn't help me with my other program. I need to first set the limits and then draw the points.
    Regards,
    Aloy
  10. #10
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,017
    Search here for min x y, max x y of a list, its lisp code, do that 1st then you have your window values, I would add a litte bit more offset.
  1. Drawing Limits
    By Coosbaylumber in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Apr 2010, 11:52 pm
  2. Drawing Limits
    By nummularius in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2006, 06:54 pm
  3. drawing limits
    By Dado in forum AutoCAD General
    Last Post: 26th Oct 2006, 10:07 am
  4. Drawing limits
    By pitts37 in forum AutoCAD Beginners' Area
    Last Post: 16th Oct 2006, 06:28 pm
  5. Drawing Limits
    By mmuste01 in forum AutoCAD General
    Last Post: 14th Aug 2006, 12:35 am
