Results 1 to 2 of 2
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    Default xrefed drawing is missplaced if it was saved while layout is active
    hi
    using acad2010,
    i notice that when i xref a drawing that was saved with its layout active ,
    i cant see it in the host, only when i resave it in modelspace active i can see it.
    any ideas? is it a a bug?
    Super Member
    AutoCAD 2010
    Dec 2010
    1,230
    for those who ecounter the same problem
    see if BASE is set to 0,0 it the xref.
    [CLOSED POST]
  1. screening an xrefed-in drawing
    By sweiss in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Apr 2013, 08:36 pm
  2. How to copy viewport to other layout/drawing with saved layer states ?
    By kruuger in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Dec 2012, 08:38 am
  3. VBA - How to edit in a not active layout
    By Grenco in forum .NET, ObjectARX & VBA
    Last Post: 15th Mar 2012, 07:22 pm
  4. copying parts of xrefed drawing
    By Urte in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2010, 01:19 pm
  5. VB.Net question - active viewport in a layout
    By Tipo166 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2009, 03:56 pm
