Results 1 to 7 of 7
    Super Member
    AutoCAD 2010
    Dec 2010
    1,229
    Default somehow the xref is off position
    hi
    i xref a drawing, with the same ucs,units as the host. but still they are not sharing the same cordinates
    any idea?
    Senior Member
    AutoCAD 2009
    Oct 2012
    337
    Attach an example.
    It's not entirely clear what you need.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,229
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Is the base point something other than (0,0)?
    Type BASE in the XREF file.
    Drafting is a breeze.
  5. #5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,229
    Quote Originally Posted by RobDraw View Post
    you right. they are different
    what sould i do?
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Set it to (0,0)!
  7. #7
    Super Member
    AutoCAD 2010
    Dec 2010
    1,229
    Set it to (0,0)!
    so simple
    thanks Rob
  1. Replies: 63
    Last Post: 27th Jun 2016, 11:35 pm
  2. sun position
    By rookie37 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Nov 2009, 03:47 pm
  3. XREF Position
    By drayle in forum AutoCAD Beginners' Area
    Last Post: 23rd Sep 2009, 11:18 pm
  4. using or within vl-string-position
    By TuFoFi in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jan 2006, 08:43 pm
