Results 1 to 5 of 5
    Full Member benhubel's Avatar
    benhubel's Computer Details
    Windows 7
    Manufacture
    benhubel's Discipline Details
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Default Select multiple entities created from command offset
    My lisp program runs the offset command, then immediately uses entlast to get the newly created polyline and add it to a selection set. There is a bug using this method, though, since offset creates multiple entities any time the offset distance is large enough to make it collide with itself. I am trying to find a way to get those additional polylines, but entlast only grabs the most recent. I am at a loss.
    The only things I can think of right now are to either write my own custom offset routine or to select everything in the drawing before and after the offset, then deselect the selection from before. Both methods sound inefficient.
    Does anybody have a better way of going about this? I found a few posts where people asked similar questions about this problem, but each one found a workaround specific to their case instead of addressing the issue of getting more than one recent entities which are output at the same time.
    For reference, here is what I'm talking about by multiple entities being created when it self-intersects:
    I just now discovered for the first time that I am prone to memory loss.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,424
    This thread may help you.
    Windows 7
    Manufacture
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Thank you. It appears to be a bit over my head, but it seems to be exactly what I was hoping for. I'll look it over and see if I can figure out what to make of it.
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    810
    You could also use vla-offset then all the items created would be stored as a list of vla-objects.
    Quick one liner
    Code:
    (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'offset (getdist))
    ;; Returns
    ;; (#<VLA-OBJECT IAcadLWPolyline 0000022d161fa478> #<VLA-OBJECT IAcadLWPolyline 0000022d161fb5b8>)
  5. #5
    Windows 7
    Manufacture
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Quote Originally Posted by ronjonp View Post
    I had no idea that vla-offset even existed. I'm surprised I've never heard of it before now. I'll definitely be checking that out, whether I use it here or not.
    **Edit**
    To be fair, I haven't had the chance to do too much with VLA in the first place. I think I should put more time into learning it.
  1. layer created & sorted base on entities colour/how to include nested entities?
    By Tripledot in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2016, 06:53 am
  2. Multiple Offset Command Error
    By DD21988 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2015, 06:03 pm
  3. selection set of bunch of newly created entities
    By MJLM in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Feb 2014, 06:09 pm
  4. Replies: 10
    Last Post: 11th Aug 2011, 05:40 am
  5. Best way to keep track of created entities for ease of removal?
    By Hudson in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2009, 01:43 pm
Tags for this Thread
