Results 1 to 8 of 8
    Full Member
    AutoCAD 2016
    Feb 2016
    Australia
    30
    Default Draw Polyline by list of coordinate
    Hello everybody,,
    how can i draw polyline by list of x,y coordinate ?? :
    list = ((x1 y1)(x2 y2)(x3 y3)(x4 y4) ......)
    example my coordinate :
    ((2420.96 1612.3) (2422.96 1612.25) (2423.96 1612.12) (2424.96 1612.24) (2425.96 1612.09) (2426.96 1612.14) (2427.96 1612.0 (2429.84 1612.0 (2430.06 1612.15) (2430.96 1612.12) (2431.96 1612.17) (2432.46 1612.17))
    Thanks in advance,
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    889
    You can use the function HERE to do this.
    Full Member benhubel's Avatar
    benhubel's Computer Details
    Windows 7
    Manufacture
    benhubel's Discipline Details
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    90
    Apparently I'm just a couple minutes too late. Still, I'll post what I wrote anyway. It's really simple and there may be bugs, but it seems to work with your data-set, at least.
    Code:
    (defun c:writepoints ( / verts index)
    	(setq verts '((2420.96 1612.3)(2422.96 1612.25)(2423.96 1612.12)(2424.96 1612.24)(2425.96 1612.09)(2426.96 1612.14)(2427.96 1612.08)(2429.84 1612.08)(2430.06 1612.15)(2430.96 1612.12)(2431.96 1612.17)(2432.46 1612.17)))
    	(setq index 0)
    	(repeat (1- (length verts))
    		(command "_.line" (append (nth index verts) '(0.0)) (append (nth (1+ index) verts) '(0.0)) "")
    		(setq index (1+ index))
    I just now discovered for the first time that I am prone to memory loss.
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Code:
    (defun C:test ( / PointList )
      (setq PointList
          (2425.96 1612.09) (2426.96 1612.14) (2427.96 1612.0) (2429.84 1612.0)
      (LWPoly PointList
        (if (progn (initget "Yes No") (member (getkword "\nClosed ? [Yes/No] <Yes>: ") '(nil "Yes"))) 1 0)
    ); defun
    (defun LWPoly (lst cls) ; LM's entmake functions
      (entmakex
        (append
          (list
            (cons 0 "LWPOLYLINE")
            (cons 100 "AcDbEntity")
            (cons 100 "AcDbPolyline")
            (cons 90 (length lst))
            (cons 70 cls)
          (mapcar (function (lambda (p) (cons 10 p))) lst)
  5. #5
    Full Member
    AutoCAD 2016
    Feb 2016
    Australia
    30
    Quote Originally Posted by benhubel View Post
    Code:
    	(setq index 0)
    Thanks benhubel, your code is work and it dont have any bugs. thanks alot for your help
  6. #6
    Full Member
    AutoCAD 2016
    Feb 2016
    Australia
    30
    Quote Originally Posted by Grrr View Post
    Code:
      (setq PointList
      (LWPoly PointList
    ); defun
      (entmakex
        (append
          (list
            (cons 70 cls)
    Grrr, Thank you for your time, your code that's what I want, thanks alot.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Another way
    Code:
    ; create pline from a list
    ; by Alan H
    (command "_pline")
    (while (= (getvar "cmdactive") 1 )
    (repeat (setq x (length lst))
    (command (nth (setq x (- x 1)) lst))
    (command "")
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Writing a lisp to draw one polyline seems an awful lot of effort with maximum chance of mistakes whilst typing all those digits.
    If your data is in the form of a csv file of coordinates, there are simpler ways of drawing a polyline.
  1. How to : Draw polyline from A list of Points And check its intersections
    By handasa in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th May 2017, 03:38 am
  2. coordinate in list not found
    By MJLM in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2015, 05:10 am
  3. Drawing Circle on List Coordinate
    By lesliematt in forum AutoCAD General
    Last Post: 16th Jul 2010, 02:26 am
  4. List coordinate by select point group
    By jason tay in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Apr 2009, 12:36 am
  5. Coordinate list
    By Moesian in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2005, 03:25 pm
