+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Senior Member
    Using
    AutoCAD 2016
    Join Date
    Oct 2012
    Location
    Well, I'm North of I-10, but South of I-94, and East of I-5, but West of I-95...
    Posts
    189
    Default
    I keep forgetting about LAYDEL...so that's what I used.
    Thanks
  2. #12
    Senior Member
    Using
    AutoCAD 2017
    Join Date
    Jun 2013
    Posts
    137
    Default
    Another reason to keep all your block elements on Layer "0".
    here's another hint. To get rid of the Defpoints layer, simply rename it first.
  3. #13
    Luminous Being RobDraw's Avatar
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,173
    Default
    Quote Originally Posted by Chilidawg View Post
    A blanket statement like that is couldn't be further from being accurate. There are many uses for blocks and some of the REQUIRE the use of layers.
    IIRC, you cannot rename it.
    Drafting is a breeze.
  4. #14
    Senior Member
    Using
    AutoCAD 2017
    Join Date
    Jun 2013
    Posts
    137
    Default
    Yeah, I know that sometimes it works to have a block use layers other than "0", I just like to simplify the control of the colors and line weights through the layer manager.
    and I have never had any problem with changing the name of the defpoints layer if there is nothing on it.
  5. #15
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,959
    Default
    If there is nothing using Defpoints, it can be purged, it will not even be created if you do not use any dimensions.
Similar Threads
  1. can't delete this layer and something else...
    By cat3appr in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jul 2016, 01:38 pm
  2. Replies: 3
    Last Post: 16th Nov 2015, 11:08 pm
  3. Cannot delete a layer
    By marlon in forum AutoCAD General
    Last Post: 18th Feb 2010, 07:24 am
  4. Cannot delete a layer
    By salmonrose in forum AutoCAD Beginners' Area
    Last Post: 3rd Feb 2010, 10:11 pm
  5. Delete layer using VBA
    By Hmm.. in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2008, 12:20 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
