Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    nasoox's Computer Details
    Windows 7
    AMD Athlon X250 Dual core 3 Ghz
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    nasoox's Discipline Details
    Surveyor
    Surveying
    Underground mine surveyor
    AutoCAD 2013
    Jun 2014
    Serbia
    25
    Smile How to make 2 surfaces with this data?
    Imagine that this image is a simple room, red line conect points for floor (KpXX), black line for top of the room (KkXX) and blue is walls(XX).
    Non of the points have same elevation.
    How to make surface at elevation from points for floor or top and with surface border from points for wall, but that surface does not connect with wall points, those points are just border of that surface.
    Surface is not horizontal, it elevates with defined points like DTM.
    Now when you have those surfaces, how to conect them and make 3D solid or Surface with vertical walls.
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    Just make the (blue) border a closed polyline, extrapolate the height you need (red line minus black line) and EXTRUDE (<- command) the object with the neccesary height?
    Full Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    25
    Yeah, only if that was that easy, that "object" have different elevation of all points and bottom and top need to follow that. blue line only defines horizontal area and shape of that bumpy surface. First I need to make surface from points with black line (line just connects points for triangulation) and that surface will go till it reach blue line and then stop, then the same thing with red line, now i would get 2 surfaces, one on top of the other, of same horizontal shape but not same in vertical, il connect them and make solid from that. Extrude does not work good at all with this.
    Full Member
    Windows 7
    4Gb DDR3
    Radeon HD5670 1Gb
    Sata II 500 Gb
    Aoc F22
    Surveying
    Surveyor
    Surveying
    AutoCAD 2013
    Jun 2014
    Serbia
    25
    This is if I can save myself from making bunch of profiles and from doing LOFT command.
  5. #5
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    They way i would do it without civil 3d is create triangles to create the 2 surfaces (manually or by some command that creates a mesh of some sort). Then use EXTRUDE on those triangles with a vertical direction (you can set the directen when extruding, see command bar).
    Use the upper surface to create an oversize extrusian and use the lower surface to cut the upper solid at the right height.
    It might be easier in some other way, but in this case it would be some 10 minute work to do it manually.
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Quote Originally Posted by OMEGA-ThundeR View Post
    If the OP can provide you with the necessary elevations can you demonstrate this for us? A finished drawing of the object in question with the steps you took to arrive at a solution would be helpful so the OP can attempt to repeat the process on his own and learn by doing. Thanks.
  7. #7
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    Sure, i can create something similar myself (principle is the same). hang on
  8. #8
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    http://autode.sk/2uEXV4a Here ya go...
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    There was no video to view.
  10. #10
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    321
    it's probably still decoding this thing on the autodesk server or something.... Autodesk screencast .
    Preparing Screencast...
    Our servers are processing your recording right now. Your Screencast should be ready in a few minutes.
    Thanks again for using our service to share your knowledge.
    Aaaand it's up .
  1. Replies: 0
    Last Post: 27th Jul 2016, 12:37 pm
  2. How to make topographic map from survey data?
    By banana1234 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2013, 01:35 pm
  3. How to make a road cross section using xyz data?
    By Zauyamakanda in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2012, 06:15 pm
  4. how can I make 3d non planar surfaces!!
    By kakody1 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2009, 04:53 pm
  5. HOW to make surfaces, etc.?
    By Briancad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Dec 2007, 01:52 am
