Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    I think the OP would have better luck with a step-by-step drawing.
  2. #12
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Quote Originally Posted by OMEGA-ThundeR View Post
    it's probably still decoding this thing on the autodesk server or something.... Autodesk screencast .
    Aaaand it's up .
    I doubt the OP will be able to follow what you did. What vertical product was used?
  3. #13
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    319
    Just Autocad 2017. And the screencast show exacly what i did. Perhaps we should wait to see if the OP has any questions after this.
    But i smell a hint of "How the hell did he do that, i want to know but i don't want to ask" in your voice
    i do know that the given information in the OP is not enough to create an acurate solid. The red line is only 2 points, you would need at least 3 to create a 'surface'-like surface.
  4. #14
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    Like Omega-Thunder maybe a guess pick 3 points make a pline, copy that pline down to zero elev removing the z elevation of each point, extrude the original pline up wards height is a dummy, extrude the bottom flat pline past the highest z, use subtract and this will make a solid with vertical sides and a sloping top join all the other extruded triangles this makes the blue shape. Take red line and create a planar solid subtract form blue solid starting to get there.
    Without a dwg a bit hard to test.
    Hopefully this is correct
    1 join 3 points
    2 copy down to zero z all points
    3 extrude over height
    4 ucs 3 pick the 3 points, draw a line end to mid, draw a circle bigger than triangle
    5 extrude circle
    6 subtract circle from extruded triangle = 3d shape
  1. Replies: 0
    Last Post: 27th Jul 2016, 12:37 pm
  2. How to make topographic map from survey data?
    By banana1234 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2013, 01:35 pm
  3. How to make a road cross section using xyz data?
    By Zauyamakanda in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2012, 06:15 pm
  4. how can I make 3d non planar surfaces!!
    By kakody1 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Apr 2009, 04:53 pm
  5. HOW to make surfaces, etc.?
    By Briancad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Dec 2007, 01:52 am
