Results 1 to 5 of 5
    Full Member
    SRN's Computer Details
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    Default publish problems
    I have a set of sheets that I tried to publish to PDF many times. Some of then come out OK but some of them the text that is in the title block that is defined by attributes comes out thinner that the specified line weight. It prints fine from AutoCAD, some sheets are fine after being published, the sheets that don't keep the line weight do if I plot them singly rather than publishing them. The properties for all the title blocks and text with them are the same, the plot styles are the same, the show line weight in the status bar is on.
    Anyone know what is going on.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,152
    Do you have multiple PDF plotters so that you can compare the outputs? Some are more consistent than others.
    breaking AutoCAD on a regular basis since 1991
    Full Member
    Windows 7
    Transport
    AutoCAD 2018
    Jun 2017
    Kentucky , USA
    27
    AutoCAD 2018 provides 5 plot options as well as batch plot. The only method that works is to plot the problem files one at a time using the DWG to PDF.pc3 method. THen combine hem using the PDf viewers tool. to get them tin the right order that means plotting the one that work that way as well. With 30+ sheets that takes a while which is a little frustrating since AudoCAD provids a tool that should do the work for me.
    Senior Member
    AutoCAD 2009
    Oct 2012
    317
    1. Attach the examples of files dwg and pdf
    2. Publication by default prints to the printer "DWG to PDF"
    3. You can do batch printing, so you do not waste time allocating 30+ files
  5. #5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    i would check the "Scale Lineweights" option in the plot dialog box. since the problem is not shared across all sheets,
  1. Publish problems
    By SAM_R in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jul 2015, 03:50 pm
  2. MATERIALATTACH and publish to PDF Problems
    By Cantilever in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Oct 2012, 10:15 pm
  3. Publish problems
    By HockeyCJ in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 28th May 2009, 09:20 pm
  4. Publish problems and baseball
    By dsheppard in forum AutoCAD General
    Last Post: 8th Apr 2009, 03:29 pm
  5. dwf publish problems
    By disbanded in forum AutoCAD Drawing Management & Output
    Last Post: 16th Mar 2008, 11:17 pm
