Results 1 to 6 of 6
    Junior Member
    AutoCAD 2011
    Jun 2011
    11
    Default Viewbase Layer Names
    Hi All,
    Just wondering if there is a system variable that i am not aware of which would dictate the of the viewbase layer names. ie. MD_Visible...etc
    Ideally, I would like to change the layer name completely to comply with my drawings standards.
    I already use Lee Mac's Layer Director to move 'Viewbase/project/section/details' commands to a 'MD_Drawing View' layer, which is useful to stop them ending up on any old layer, but there seams to be no way of changing where the 2D geometry goes.
    Surely this would be an easy thing for Autodesk to change but in the time being, anyone have any ideas?
    Cheers
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I don't believe the viewbase layer names are controlled by a system variable. You would have to use the RENAME command to change them or override them in the Layer Properties Manager.
    Junior Member
    AutoCAD 2011
    Jun 2011
    11
    Unfortunately 'MD_Visible' is a fairly meaningless name in relation to our drawing standards but my users are too disinterested to change the default names using conventional means.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You'll have to talk to the good folks at AutoDesk regarding the "fairly meaningless" layer names. Until such time as they see things your way you can use a lisp routine or even a script to rename the layers as you see fit.
  5. #5
    AutoCAD 2013
    Nov 2011
    5,992
    Quote Originally Posted by JWhelp View Post
    Hi All,
    Cheers
    It has been a while since I used Viewbase, but I seem to recall that if you changed those layer names, that the next time you used it, those layer names would be used.
    Untested, but that seems to ring a bell. Hope I am correct.
    Or you could use the LAYTRANS command (with wildcards *) to do it, after the views had been generated.
    I did a test, and it seems my recollection may have been erroneous.
    What you can do in the Layer Manager after creating the views, select the viewbase layer names ending in Hidden, and in my case, I then right click and select merge selected layers to, and then I select Steel Hidden, as that is the layer I want them on.
    Then I choose the Visible layer, and repeat that process, but choose the layer Steel, as that is the medium in which I am working, and the layer where I want them to display.
    After you do that, they will look like a drawing you did yourself, with appropriate coloration.
    LAYTRANS may be your best bet, for an in house solution.
  6. #6
    Junior Member
    AutoCAD 2011
    Jun 2011
    11
    LAYTRANS is something I'd not seen before. Could work in combination with a script/reactor to keep the layers in check.
    Thanks very much for the input chaps.
  1. Layer names
    By mathew21 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2012, 11:36 pm
  2. Layer States and Xref Layer Names
    By DanFHiggins in forum .NET, ObjectARX & VBA
    Last Post: 7th Dec 2011, 03:51 pm
  3. Converting layer names to point names or comments
    By codral in forum AutoCAD Drawing Management & Output
    Last Post: 1st Dec 2011, 02:01 am
  4. Change Layer Prefixs and Layer Names
    By ML0940 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 11:11 am
  5. Layer names
    By RHOS1355 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jun 2006, 11:19 pm
Tags for this Thread
