Results 1 to 4 of 4
    Full Member
    Manufacture
    neondeon298's Discipline Details
    CAD Specialist / NDT
    Manufacture
    AutoCAD 2017
    Dec 2016
    38
    Default Arc Length... How do you do it?
    Mmmmk. I have to put anomalies into a pipe at certain degrees and locations. I am given the OD, and the OD arc length distance from 0° to the anomaly. So what I do is trig and calculate the degree via "arc length=2πR*(C/360)". Get my angle, draw my line from center.
    Is there any easier way of just placing an arc start point, the radius and how long you want it!?!?!?!
    AutoCAD 2017 btw.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    You can draw an arc of the radius needed, any length. Then use Lengthen command to set to actual length needed.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    311
    Do not remember in AutoCad but in DraftSight you can use DRAW -- ARC -- START END RADIUS which i think rkent is telling you.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    if you are happy doing a bit of calculation, you could streamline getting the angle.
    Divide the arc length by the diameter. This gives the angle in radians which you can enter when drawing your arc. Probably 4 decimal places is enough and put an "r" immediately after the numbers. AutoCAD will understand that the angle is in radians without having to change the angle units.
  1. Length Isn't Everything.
    By Netminder in forum Autodesk Inventor
    Last Post: 21st Nov 2011, 07:34 pm
  2. Replies: 2
    Last Post: 11th Oct 2011, 12:41 pm
  3. Need Lisp to create stock length with Lap length
    By rajeshmuthu in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Oct 2011, 06:10 pm
  4. Cut Length VS Lay Length of the Pipe
    By DIW_HDsupply in forum MEP
    Last Post: 24th Mar 2011, 05:38 pm
  5. Specifying the arc length of any given arc.
    By rjracad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th Aug 2009, 07:41 am
