Results 1 to 5 of 5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,229
    Default Isolating xref (and not its individual objects)
    hi
    i want to isolate the whole xref (like unload) rather than its indevidual layers. is there a way of doing so with no lisp?
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    i wouldn't know any way without a lisp unless you want to enter a few of commands .
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    If you make a new layer, and insert the x-ref onto that layer, then freezing that layer makes the x-ref disappear. Saves having to individually freeze each of the x-ref's layers.
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    "...isolate (like unload)"...
    Ok, isolate is to make that single object visible and unload is to make it disappear. What needs to be the end result??
    In the case of making is disappear i would use the command 'Hideobjects' when selecting the xref object.
    Use 'UNISOLATEOBJECTS' to make it appear again (its different from layon / layiso and freezing layers).
    A lisp i use:
    Code:
    (Defun c:hideob ()
      (command "HIDEOBJECTS")
    (Defun c:showob ()
      (command "UNISOLATEOBJECTS")
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Layer manager. Select the "All non-Xref Layers" filter. Freeze all layers except for the on that the XREF is on.
    Or without messing with layers use the ISOLATEOBJECTS command.
    Drafting is a breeze.
  1. VPFreeze individual OBJECTS?
    By Sbeth85 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Oct 2013, 03:53 pm
  2. Creating hatch boundries on multiple objects and individual lines.
    By Jonathan1321 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2013, 01:00 pm
  3. Isolating Objects in AutoCAD 2011
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 24th Nov 2010, 02:20 pm
  4. Rotating Objects about their individual centers
    By stopandgo in forum AutoCAD Beginners' Area
    Last Post: 14th Sep 2009, 09:20 pm
