Results 1 to 4 of 4
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    Default keyboard shortcut wont work
    hi
    for some reasom
    in the CUI
    1.im loading a partial costume file
    2.im loading the lisp file
    3.Keybord Shortcut > New > Overriden Keybord Shortcut
    notes:
    using acad 2010
    it seems like autocad ignore the defined combination i declare, instead, it evaluated as is
    any idea?
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    744
    Assuming you're talking about 'Keyboard Shortcuts' → 'Temporary Override Keys' the ones in the Main CUIX file will take precedence.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    Quote Originally Posted by tombu View Post
    i tried to set it in the main CUI (Shift + Key)
    but Shift + Key wont even trigger any command
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    744
    First what's the macro you want to assign?
    'Keyboard Shortcuts' → 'Shortcut Keys' which can be assigned to commands you use frequently are very different than 'Keyboard Shortcuts' → 'Temporary Override Keys' which are generally used while a command is in progress to toggle an option. While Shift+Key works as a 'Temporary Override Key' for most keys Shift+letters would put capital letters to the command line when entered otherwise.
    The Command Alias Editor is an option as well.
  1. Keyboard shortcut (OSNAP) doesn't work
    By rustedbar in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 26th Nov 2012, 03:38 am
  2. shortcut commands wont work
    By khair in forum AutoCAD General
    Last Post: 21st Mar 2012, 02:06 pm
  3. Keyboard shortcut for delete
    By Max2011 in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2011, 02:23 pm
  4. My keyboard shortcut is MIA
    By BOB'27T in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2007, 11:35 am
  5. Shortcut keyboard
    By Ducati in forum AutoCAD Beginners' Area
    Last Post: 21st Jun 2005, 06:17 am
