Results 1 to 3 of 3
    Super Member
    AutoCAD 2010
    Dec 2010
    1,204
    Default Controlling a linked dwg after it was linked
    I've linked a dwg as colorful drawing, now i want to to appear as black. Is there elegant way to do it?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Visibility/Graphics > Import Categories. Expand the DWG and Shift+select all the layers. Change the Lineweight (use a 3 minimum) and Line Color to Black.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by tzframpton View Post
    I'm sure you know, but I want to make sure others are aware that that number is arbitrary. There is a lineweight assigned to that number. It is possible that the assigned value, or the default for that matter, would not be suitable for the .dwg.
    Drafting is a breeze.
  1. Linked Value in MText
    By TOS-TrekFan in forum AutoCAD Beginners' Area
    Last Post: 31st Mar 2017, 01:57 am
  2. linked DWG for some groundwork
    By halam in forum Revit General
    Last Post: 7th Nov 2016, 03:57 am
  3. Replies: 11
    Last Post: 23rd Jun 2016, 09:42 pm
  4. Other software packages linked to CAD
    By Chippie86 in forum AutoCAD Beginners' Area
    Last Post: 23rd Nov 2011, 03:28 am
  5. Controlling Layer Visibility in a Linked Model
    By rab in forum Revit General
    Last Post: 28th Apr 2010, 06:51 pm
