Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2015
    Jul 2017
    1
    Default Offset for a callout, Is there a shortcut for this result?
    Hello everybody
    I do drawings that have to have call outs. However, sometimes the call out line crosses with lines of the drawing so every call out line has to have an offset of .025, this way, the line only touches the item im calling.
    Currently, I do an outside offset on the line both ways, then I use trim and cut everything inside. Sometimes my figures have up to 50 call outs and I have to do this process that is very time consuming.
    Is there a way I could to this faster? I thought maybe i could put a blank line below my callout line, that had the width of the offset. Or maybe two blank rectangles that had the space of the line between them. I'm new in AutoCad and I'm having some trouble trying to solve this.
    Note. I copy and paste my drawings to word with paste special Picture (Windows Metafile) so it has to look the same as autocad.
    Example.
    Last picture is the result I need.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    You can use a custom leader atyle with a user block containing an attribute for your text. Now, since it is a leader you can have a fixed length or stretchable upon insert leader line with or without an arrowhead, and insert automatic breaks in the leader line for each line that it crosses, after you have inserted and poitioned your callout (leader). Define and save the block with text attribute first, it need only contain the text attribute. Then do the leader set up selecting to make one with a block attached, then select User Block, then browse to the block you previously created. Common drafting practices say that you should NEVER break the lines that make up your drawing objects.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Callout Customization
    By nnutting in forum Revit General
    Last Post: 1st Jul 2016, 09:09 pm
  2. Dumb Callout
    By addesigns in forum Revit Architecture
    Last Post: 31st Jul 2013, 12:46 pm
  3. Section Callout
    By cmlucifer in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2012, 05:50 pm
  4. Callout Dimenstion Twice
    By Mike_Taylor in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Jan 2012, 03:19 pm
  5. Callout Lisp
    By Tankman in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 04:00 pm
Tags for this Thread
