Results 1 to 3 of 3
    Forum Newbie
    Solidworks 2015
    Dec 2015
    6
    Default How to reduce segments in DXF file
    Hello! I am extracting points coordinates (X,Y) from DXF file. The problems is that there are tens of thousands of points extracted, but I need up to few hundred points. How can I reduce the number of points and segments. The files are exported from Eagle (PCB design) and it is not too complex. I can't export new files with smaller amount of points and lines, but I can work with the DXF files using AutoCAD. Thanks a lot!
    Senior Member
    AutoCAD 2009
    Oct 2012
    317
    Comand line:
    _overkil
    Forum Newbie
    Solidworks 2015
    Dec 2015
    6
    Thank you! this definitely works.
  1. Reduce many segments
    By sivapathasunderam in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Feb 2017, 11:43 pm
  2. Reduce 3ds file size?
    By bm23 in forum 3D Modelling
    Last Post: 22nd Nov 2012, 06:51 am
  3. How TO REDUCE CAD FILE SIZE?
    By nisman in forum AutoCAD Drawing Management & Output
    Last Post: 10th Jan 2010, 03:53 pm
  4. How can I reduce my file size?
    By chillrender in forum AutoCAD Beginners' Area
    Last Post: 14th Mar 2009, 01:35 am
  5. pdf.pc3 file size? help reduce
    By WCCSAM in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jan 2009, 07:01 pm
