Results 1 to 7 of 7
    Forum Newbie
    Mechanical
    AutoCAD 2015
    Jul 2017
    9
    Default VBA Autocad: How to find lines?
    I'm trying to write a VBA code that searches in a general drawing all lines that have a specific length and slope. Then, every time it finds that line in the drawing, it will write next to a specific text, for example "line". Do you think it's possibile? Any idea? Thanks
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    In principle what you want to do is perfectly possible.
    You search the current drawing filtering on lines to create a selection set. Then loop through the selection set and write your text at your desired position.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    As VBA
    Code:
    Dim FilterDXFCode(0) As Integer
    Dim FilterDXFVal(0) As Variant
    FilterDXFCode(0) = 0
    FilterDXFVal(0) = "LINE"
    Set SS = ThisDrawing.SelectionSets.Add("Linelens")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    For Cntr = 0 To SS.Count - 1
    'now get the length etc and do something
    As lisp
    Code:
    (setq ss (ssget (list (cons 0 "Line"))))
    (setq obj (vlax-ename->vla-object (ssname  ss (setq x (- x 1)))))
    (vla-get-length obj)
    (princ "\n")
    Senior Member
    AutoCAD 2009
    Oct 2012
    320
    Quote Originally Posted by ElCidCampeador View Post
    Can.
    Write all the requirements, and attach an example.
  5. #5
    Forum Newbie
    Mechanical
    AutoCAD 2015
    Jul 2017
    9
    Thank you all! It works...!
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    What worked ? You dont have to post the code just how, others may want the same answer.
  7. #7
    Forum Newbie
    Mechanical
    AutoCAD 2015
    Jul 2017
    9
    I used your idea Bigal, vba
  1. Cant find lines in block
    By byk3bep in forum AutoCAD Drawing Management & Output
    Last Post: 11th Feb 2016, 01:50 pm
  2. Find unsnapped lines
    By cmscardoso in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2014, 05:08 pm
  3. find intersection of 3D lines
    By giskumar in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jan 2013, 12:58 am
  4. Replies: 6
    Last Post: 13th Jul 2011, 02:19 pm
  5. find crossing lines and break them down
    By epsi1on in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2011, 11:42 pm
Tags for this Thread
